October 4, 20188 yr comment_161607 How do I size a Fenner link belt(s) for my drill press? They are available in several profiles and I'm not sure how to spec the right one. Thisisn't about length, but rather the width/depth/angle stuff. Edited October 4, 20188 yr by Fred W. Hargis Jr Report
October 4, 20188 yr comment_161633 You'd probably get the most accurate answer to your question by contacting Fenner Drives and asking them. Report
October 4, 20188 yr comment_161637 Here's something I found that may be helpful. http://www.fennerdrives.com/install/ Check the PowerTwist V-Belts Report
October 5, 20188 yr comment_161658 Not a fan of link belts. I'd put a good brand v-belt on it. Report
October 5, 20188 yr comment_161669 Other than the Shopsmiths that use belts specifically for those machines, my only other belted machine is the shop built "Flat Sander". It had a v belt that wore out. I replaced it with a link belt. It has been working great and has lasted longer than the v belt did. And, it's a great deal quieter, too. Report
October 5, 20188 yr comment_161687 5 hours ago, HandyDan said: Not a fan of link belts. I've got to ask why ? Report
October 5, 20188 yr Author comment_161688 My DP has premium power transmission V belts (Gates POWERATED brand) on it now, and it's not as smooth as I want. I've used a link belt in the past on a cabinet saw and it really was a step up in smooth operation. The belts I have were installed a couple of years ago, and i don't use the DP that often, so it's not that big a deal. But I would like to see it run more smoothly. Edited October 5, 20188 yr by Fred W. Hargis Jr Report
October 5, 20188 yr comment_161700 7 hours ago, CharlieL said: I've got to ask why ? Link belts were made to replace broken belts in a situation where "quick" access to the right belt is limited. Good belts run smoothly and and last a long time. When they get old they should be replaced as with most things. Link belts rarely if ever are used as OEM. I feel there is a reason for that. Not trying to change anyone's mind. Just my opinion. Report
October 5, 20188 yr comment_161704 I have been using the Fenner Link Belt in two Contractor's table saws for quite a few years. I like the link belts, and will continue to use them. Edited October 5, 20188 yr by CharlieL Report
October 5, 20188 yr comment_161707 Just a guess but, I'd imagine the reason link belts are rare on original equipment is purely financial. Report
October 5, 20188 yr comment_161711 I have link belts on all my belted equipment. and like them. Herb Report
March 7, 20206 yr comment_220721 I have lots of experience with link belts. I dislike the plastic stuff. Just run a tape measure around your pulleys and buy a few inches longer. It's easy to remove a few links. This is the best stuff you can buy... Supreme V-link belting. Report
March 7, 20206 yr comment_220725 27 minutes ago, Kevin Beitz said: I have lots of experience with link belts. I dislike the plastic stuff. Just run a tape measure around your pulleys and buy a few inches longer. It's easy to remove a few links. This is the best stuff you can buy... Supreme V-link belting. Where do you get yours from?? Report
March 7, 20206 yr comment_220759 Not recommended for use on die-cast pullies. They tend to cut their way through the softer metal. Report
