July 25, 20188 yr comment_155031 I needed a piece of wood about 2"X 2" any thickness. I always look for nails, screws, etc. None showing so I cut on the bandsaw and it started out ok and then I knew I run into something. The saw slowed down and it went for over an inch at the slow speed then it speeded up and I finished the cut. There was 2 halves of a screw cut lengthwise right smack down the center. If I had tried to do this on purpose there is no way I could of done this good of a job. Am enclosing a picture. I clamped the 2 pieces of wood together showing both halves. Preston Report
July 26, 20188 yr comment_155046 Darn good BS blade to do that. I never had one that would continue after hitting a screw/nail. Herb Edited July 26, 20188 yr by Dadio Report
July 26, 20188 yr comment_155074 You're good Preston. Out of curiosity, what brand/type is the BS blade? Report
July 26, 20188 yr Author comment_155079 Its a 1/4" standard teeth on a 14 " Delta. The teeth are not carbide. Preston Report
July 26, 20188 yr comment_155080 59 minutes ago, steamshovel said: Its a 1/4" standard teeth on a 14 " Delta. The teeth are not carbide. Preston ...and the brand of blade? Report
July 27, 20188 yr Author comment_155179 I finally found out the brand of the bandsaw blade. Its a Lennox. I called and talked with the place where I bought the blade. His business is about 35 miles from my home. I go there because he does a super job sharpening and sells great products. Dave Paleuse Resharp 1-800-733-7297 Report
October 15, 20197 yr comment_205305 I hit metal all the time on the mill. You should try a ceramic insulator... Report
