Posted
Never would have thought to mount the saw vertical. Now how big of a log will fit in it and how do you drag it into position?
Posted
4 hours ago, brianpoundingnails said:
I mounted it vertical so I could plunge cut the ice chests. I either lift it onto the bed with my engine hoist, or roll it up a ramp from either end. Mostly I use the chainsaw function to cut uniform half rounds for those tables, then take the cant to a local sawmill to slice up. The half rounds are worth more to build those tables than the rest of the boards or anything I could make out of them. The bed will accommodate a 24"dia x 99" log. That was a design goal. For longer logs I use my Alaska mill to cut. Every now and then I find a crotch or burl to cut. When I first started I would cut anything I could get my hands on. I'm mostly cutting red cedar and cypress and they don't weigh near as much as hardwoods.
WELL THROUGHOUT OUT GOOD LUCK.
Posted
Awesome piece of machinery. I certainly admire your talent as designer, machinist and fabricator. Great job!
Posted
 Wow, for your application you definitely have it figured out. From the looks of the attachments on the wall all you lack is a name plate & a patent number.
  • Like 2
Posted
That is a kool rig. I didn't see any chips though, where is the saw dust?
Herb
  • 3 years later...
Posted
I am also interested. More wanting to know what size flatbed with crane I need to collect logs for small milling operations.
After a bit of research, I've found a publication of from U. of Tenn / Ag detailing the weights of logs. The PDF is attached. Good reading!
Estimating Weight of Logs and Standing Timber
https://extension.tennessee.edu/publications/documents/sp748.pdf
Estimating Weight of Logs and Standing Timber.pdf
  Only 75 emoji are allowed.
