May 27, 20188 yr comment_150298 Its real important to keep the coils clean and dust free as much as possible in the summer time... or any other time to get good results from your unit... After I change the furnace filters in the house I clean them and reuse em for the shop cooling.. Well I hit the wrong button as I went to load a picture... so heres the picture. Its a 28,000 size and it does a great job even on the hottest days. But I also got the 6" walls stuffed full of insulation... I know some dust goes in the coils from the bottom but I can see the front gets full also so it does help.... If you don't do something like this you'll be sorry!!!!!!!! I bought this unit in 99 or 2000 and am now crossing my fingers hoping. Edited May 27, 20188 yr by Smallpatch Report
May 27, 20188 yr comment_150304 For a unit its age, those are some real hi-tech, space age filter retainers. Must be complicated to change? I'd have to read the manual first. Report
May 27, 20188 yr comment_150309 59 minutes ago, Grandpadave52 said: For a unit its age, those are some real hi-tech, space age filter retainers. Must be complicated to change? I'd have to read the manual first. At least we know the silver side goes out. Report
May 27, 20188 yr comment_150310 Up north here this is out time of year. During winter we go from heated space to heated car to heated space. Summer is the reverse for you and you go from cool space to cool car to cool space. Report
May 27, 20188 yr Author comment_150314 Say what???? You mean you don't have to have an air conditioner in the summer in your shop???? That sounds criminal!!!. Edited May 27, 20188 yr by Smallpatch Report
May 28, 20188 yr comment_150322 2 hours ago, Smallpatch said: You mean you don't have to have an air conditioner in the summer in your shop???? 440 Unit...4 windows open with four fans blowing hot air. Report
May 28, 20188 yr comment_150339 15 hours ago, Smallpatch said: Say what???? You mean you don't have to have an air conditioner in the summer in your shop???? That sounds criminal!!!. My shop is in the basement so it is climate controlled same as the house year round. Report
May 28, 20188 yr Author comment_150342 Ron Pemberton did you see the weather forcast I posted for Breckenridge a few days ago?? Decatur's weather will more than likely be the same as Breckenridge's and I have never seen a 10 day forecast this high ever. We were planning to go to the first Monday next weekend in Weatherford. There's not a lot of trees to walk under so our stay might be in minutes and not hours like in the past...First Monday is great for I get lots of the tools I use from that place and a few old planes and draw knives..I got to where I take a list of things I look for.... We really like Canton better but wife is starting to hate the drive through Fort Worth and Dallas on 20 and to get there from Breckenridge that's about the only road unless one chooses some cowboy trail to go down!!! Edited May 28, 20188 yr by Smallpatch Report
May 31, 20188 yr comment_150576 I gave up. A swamp cooler just rusts every thing up. I spent more time cleaning coils on an A/C unit than I did working. Here in Texas when it get past 95 (2-3 weeks ago) I just go on nightshift. Not that that helps much, in another month it will be 100 degrees at 4-5 in the morning. Not much you can do but sweat it out. Report
June 1, 20188 yr comment_150619 I've tried several things here in Phoenix, including AC-ing a small area. Best solution is a small (300 cfm) evap cooler that you roll/point at your work area, which does mean it works a lot better for bench work. It doesn't change the humidity in the overall room that much, so not much rusting. It points at an area (position it about 5' from where you will be), and does feel better than just a fan. Got it HD for about $150. Reservoir of water (I'd use distilled) lasts about 2 hours, so it's not a permanent thing. Helps at times. Report
