March 12, 20188 yr comment_143159 Hello, My grandfather gave me all of his wood turning tools that he brought with him from overseas before moving to the greatest country, America. I’m wanting to fix up the wood lathe. Do you guys have any 1hp+ motor(s) suggestions? I have even noticed folks using motors from other types of equipment to run lathe. I’m hoping to stick around $200 range. thank you! Report
March 12, 20188 yr comment_143194 Which lathe it it? 1/3 or 1/2 HP motors were common on the smaller lathes such as the old Sears tube style lathes. Wish you would sign in to the forum and stay a while. We would be glad to have you and you could ask away in the Turning Forum. Report
March 13, 20188 yr comment_143217 Do you have the old motor and the info plate data from it? That might help folks tell you their suggestions. Welcome and please do stick around. Report
March 13, 20188 yr comment_143232 Try Grainger but like Toad said you need to look at the old motor to determine which motor to use. Report
March 13, 20188 yr comment_143242 The tag on the old motor should show the direction of rotation, rpm's, hp,. Be sure to measure the shaft with calipers in both Metric and Imperial, the motor base size is usually called out on the tag for the bolt hole arrangement. Might want to take a picture on your phone of the name plate to show to the guy behind the counter. Herb Report
