January 2, 20188 yr comment_135875 Since I'm not an electrician, I need good advice . I'm wanting to get a couple of 4 or 6 outlet cords with surge protection for electronic equipment, ie ,computer, TV and the rest. Protection is rated by joules and I'm wondering how many joules protection are needed to protect this equipment . I have looked at cords rated at 1500 joules and others rated at 3600 joules. Both have 14 ga wiring rated for 15 amp outlets. What is recommended for reasonable protection. I know that whole house surge protection can be installed, but as of now it hasn't been installed in my home to my knowledge. Edited January 2, 20188 yr by It Was Al B Report
January 2, 20188 yr comment_135878 i have several units by Tripplite (they make Isobar surge protectors) https://www.tripplite.com/products/surge-protectors~19 similar to the following and have had good results from them. Edited January 2, 20188 yr by p_toad Report
January 2, 20188 yr comment_135882 Here are a couple of articles with joule information. http://techunl.net/blog/surge-protection-how-many-joules-enough-protect-my-computer http://onsitelogic.com/tag/minimum-joules-for-computer/ Report
January 2, 20188 yr Author comment_135943 Thanks guys ! Very helpful information. Years ago, when I was welding at the shipyard, after making repairs on a submarine hull, there were electronics hooked up to that part of the hull and a predetermined number of joules was introduced to that section to heat the hull to a predetermined temperature, I think 300 degrees F for a specific time period. This was done to insure the metallurgical grain structure of the weld and hull material were precisely balanced. Report
January 13, 20188 yr comment_137079 Hey Al.. What did they do back then when the Titanic went down due to bad steel? Report
January 13, 20188 yr comment_137081 Al, just got a sale "flyer" from our utility co. with a couple surge protectors listed: https://www.georgiapowermarketplace.com I have not shopped around to know whether those prices are good or not, but link provided for your info. Report
January 13, 20188 yr Author comment_137099 3 hours ago, Larry Jenkins said: Hey Al.. What did they do back then when the Titanic went down due to bad steel? I guess the modern technology might not have made any difference Larry. The ship that they used the joule technology on was unfortunately the Submarine Thresher. I knew many of the crew members and shipyard workers aboard. Still no official cause for this catastrophy. Report
January 13, 20188 yr Author comment_137100 Cal, I went to HD and picked up one with 8 outlets providing 3600 joules of protection. $29.00 Report
January 13, 20188 yr comment_137135 We had a presentation this morning from one of the guys in the woodworking club who is an electrician. He did a presentation on surge protection. Two three important points. Surge protectors have a finite life and you get what you pay for -- 3-5 years for the medium quality MOV ones ($25-30). The $6 ones are not worth it. Next jump up is series at $200-250. Joules is not what you want to look at -- it's voltage protection rating that counts. To be tested and certified it must be UL Listed. They will add all sorts of other meaningless modifiers that don't mean anything (sort of like finishes ) Here's a copy of his presentation, plus an earlier one he did on general electrical safety Surge Protectors - Gene Wiggs - Jan 2018-1.pdf 2017 Electrical Safety in the Shop - Gene Wiggs.pdf Edited January 13, 20188 yr by kmealy Report
January 13, 20188 yr Author comment_137143 Thanks Keith. The unit I got at HD is rated UL 1449, 400V. I don't plan to spend $200.00 + for a surge protector unless it's a whole house protector. Report
January 13, 20188 yr comment_137147 23 minutes ago, It Was Al B said: Thanks Keith. The unit I got at HD is rated UL 1449, 400V. I don't plan to spend $200.00 + for a surge protector unless it's a whole house protector. Right. He said those $200 ones are the ones used by his brother who works on organs, by a lot of the traveling bands to protect their $ music equipment and the $7000-9000 home theater systems that are professionally installed. He says he has one (he's pretty anal about this electric stuff), to protect his computer and his wife's computer (and all her photos -- he cited cost of recovery). Hence the last slide -- backup (your files). Report
January 13, 20188 yr comment_137159 That's part of the reason i have a UPS and a surge protector chained to my computer. Had to replace the battery once on the UPS, but it was the best money i ever spent protecting my PC and associated equipment from power blips and outages. Report
January 13, 20188 yr comment_137162 25 minutes ago, p_toad said: Had to replace the battery once on the UPS, look to emergency lighting batteries the next time... better batteries for less money.... Report
