December 3, 20178 yr comment_133143 I'm putting a remote start on my slider. I gotta make the thing myself because the electrics in my Hammer Saw are confounding and are not simply start and stop. There are capacitors that must be engaged and held so until the blade spins up. Germans like doing things that way. I'm doing it about like I did the remote for my DC. I'll have two solenoids literally pushing the on off buttons. A switch box on a coil of head phone wire from overhead and a 24 volt switching power supply. It looks a tad silly but it works. The springs in my saw's switch plate are too string for the cheap little solenoids I get from China on the Fleabay so I'm using levers for mechanical advantage. Edited December 5, 20178 yr by Ron Dudelston tags added Report
December 3, 20178 yr comment_133159 just change the switch.. AB wiring schematics.pdf AV MOTOR CONTROLS.pdf Control_Circuit_Schematics_0507.pdf eaton-motor-control-basic-wiring.pdf start stop stations.pdf WIRING DIAGRAMS.pdf Report
December 4, 20178 yr comment_133223 This should be all you need. Make sure the contactor is the correct voltage and has a NO auxiliary contact. Report
December 4, 20178 yr comment_133255 Sounds complicated, Cliff. Out of curiosity, why a remote switch for the saw? Report
December 4, 20178 yr Author comment_133308 7 hours ago, Gene Howe said: why a remote switch for the saw? well with a slider the switch is placed so the operator has to reach down around the slider to access it. Put a sheet of ply on the slider and you gotta grovel around on you hands and knees to find the switch. So an over head pull down switch is really nice. Report
December 4, 20178 yr comment_133309 17 minutes ago, Cliff said: well with a slider the switch is placed so the operator has to reach down around the slider to access it. Put a sheet of ply on the slider and you gotta grovel around on you hands and knees to find the switch. So an over head pull down switch is really nice. Gotcha. Totally understand. Thanks for the clarification. Report
December 4, 20178 yr Author comment_133311 Here she be https://photos.smugmug.com/Tools-I-made-or-Purchased/i-Cx3mJZj/0/40b32ea2/1280/20171204_153352-1280.mp4 Report
