September 30, 20179 yr comment_126567 If you live near a Menards, and could use some brad point bits this may be of interest. They have the Montana 6 piece set on clearance. I picked this deal up on another forum, and bought a set for myself. For the record, I've had the excellent LV set for many years, and they still cut very clean holes...but they also cost quite a bit more. I tried the Montana bits (made in USA) and they do a very acceptable job, though they aren't as clean cutting as the LV. So if you need a set of brad points (and have a Menards nearby) these are a very good buy. You can check your local store and see if they have any on the shelf at the link. Report
September 30, 20179 yr comment_126574 Thanks! Wish we had a Menards. We don't have a Costco either. Report
September 30, 20179 yr comment_126596 I'm not sure who does who but Hitachi and Montana brand are the same. Something to think about... I buy both depending who is cheaper.. Report
October 1, 20179 yr comment_126608 3 hours ago, BillyJack said: Hitachi and Montana brand are the same. Montana Tools.... any Hitachi bit I have ever used has been less than satisfactory... Report
October 1, 20179 yr comment_126613 Was in Menards the other day.....they still had a few sets of the Montana bits......sitting right beside the "Tool Shop" sets.....don't have a need for them, at the moment... Report
October 1, 20179 yr Author comment_126635 7 hours ago, Wichman3 said: The closest Menard's is over 400 miles away, so... That would definitely make them more expensive than the LV! Report
October 1, 20179 yr comment_126639 10 hours ago, Stick486 said: Montana Tools.... any Hitachi bit I have ever used has been less than satisfactory... Here are a couple things I use from both that have worked well....I did change to the Dewalt flips for countersinking as the Montana brand were getting harder to find... Report
