August 26, 20179 yr comment_122338 I needed to cut some splines for a Walnut door for a rifle display case I'm building and thought I'd do it on the CNC. Here's the door with splines before gluing and sanding - And here's the video on making this - Enjoy! David Report
August 27, 20179 yr comment_122435 If the blank for the splines is a little thick you can raster the thickness before you cut them out and save time sanding later. Report
August 27, 20179 yr comment_122439 One other thing David didn't mention the grain in the spline should be running the length of the spline and not across.. David did cut the splines correctly, I just wanted to let others know because I have had people want to know why their joint failed when they added a spline to strengthen the joint, their spline had the grain running across instead of along the length. Report
August 28, 20179 yr comment_122507 17 hours ago, MEBCWD said: One other thing David didn't mention the grain in the spline should be running the length of the spline and not across.. David did cut the splines correctly, I just wanted to let others know because I have had people want to know why their joint failed when they added a spline to strengthen the joint, their spline had the grain running across instead of along the length. As St.Roy says, "Planes of strength and planes of weakness." Report
