Posted
This is a practice bridge out of Walnut for the guitar I'm building. The actual bridge will be East Indian Rosewood but since I have a lot more Walnut than Rosewood I wanted to make certain my design would work so that lead to a practice bridge.
David
Here's the finished bridge -
And here's a video of the entire process -
Posted
I'm sure someone already asked...but are those bits in your CNC HSS, carbide, or ???   Thanks for the video.  :)
Posted
Carbide. I don't think I have any HSS bits, come to think of it...
David
Posted
David
Got it.   Thanks!
Posted
Ok, I made another bridge, smaller this time. The first one is 32 grams and this one is 20 grams. This is the size I intended it to be but the first one was more about testing my CNC programs. This one is more about getting the size correct. Yes, I could have done this all in the same bridge but I like making them and I have a ton of small Walnut pieces on which to practice.
Here's the one I made this afternoon, on top of the first one (the leading edge is lined up and they are the same length - camera parallax factor comes into play) -
5986698875212_012-Smallerbridgeontopof1stbridge.JPG.61047743d553c7f3877bbdb0c469d9eb.JPG
And here they are as a comparison; you can see how much smaller the one made today is -
David
  • Like 2
Posted (edited)
Okay make a bigger guitar for the old bridge.:P
Really like the profile and your solution to the problem.  Great pictures as always.
David you could add embellishments to the sides like little flowers, dragons heads or furniture flourishes, V-carved or 3D to make it one of a kind.  V-carved would reduce the weight a little but the 3D would add to the weight but also the look.
Edited by MEBCWD
  Only 75 emoji are allowed.
