June 25, 20179 yr comment_114399 Based on a YouTube video demonstration by The Wood Whisperer, I drew plans and built my own version of an exact width dado jig. I have been using it for a couple of years and it works great. Mainly I have used it to cut dadoes for cabinets pieces...50 + cabinets and counting! Same basic principle as Marc's, one side is stationary and the other is adjustable. Just place a representative piece of material in the jig and cinch snug and tighten the knobs. Then, using a 1/2 inch pattern bit mounted in a router, rout the dado. I usually make my dadoes 1/4 inch deep so two passes will do nicely. I made the jig large enough so base cabinet sides can be cut as well as uppers. And, if you are only needing a one off dado job, you could always make a stationary sides and cut away. Simple template routing. Also, when I needed to make a stopped dado, I added a stop block with a screw. Worked well also. I hope you like the plan. Use it and have fun. Mike Edited June 26, 20179 yr by MT Stringer typo Report
June 26, 20179 yr comment_114427 Hey Thanks Mike for the detailed drawings. Great post! Just a suggestion while Edit is still open...you might go back and enter some tag lines. Down the road it could help others when doing a search for fixtures/jigs of this type. Thanks in advance...If you have questions on adding Tag lines, Lew will answer them Report
June 26, 20179 yr comment_114443 8 hours ago, Grandpadave52 said: you might go back and enter some tag lines. THANKS Mike...Great job... Help yourself Report
July 5, 20188 yr comment_153198 Guys, I'm wondering if you have made any changes/improvements to this jig? I was thinking of adding some way to hold it without clamping it?? Edited July 5, 20188 yr by Pat Meeuwissen Report
July 5, 20188 yr comment_153199 7 minutes ago, Pat Meeuwissen said: I was thinking of adding some way to hold it without clamping it?? I'm interested now... Report
July 5, 20188 yr comment_153201 Stick I was LOOKING for a way to do it. Don't have one myself. Report
July 5, 20188 yr comment_153202 a pair of straight edge guides or a holding system like they have??? Report
July 5, 20188 yr comment_153203 Affix one of these to the fixed side and or both sides beside the guide board. Report
July 5, 20188 yr comment_153205 that's what I said... connect two of them together w/ a locking slide bar... use a top bearing mortising bit for simplicity.. skip the guide board... Report
July 6, 20188 yr comment_153333 How about the idea of adding threaded rods through the width of the outer guide? Add t-nuts or threaded inserts to provide the threads in the guide. This would fix the jig to the part being dadoed without needing clamps - a quick and easy modification to an existing jig too. Report
