June 10, 20179 yr comment_112438 I was looking at a CL ad for a welder. The ad reads: "Miller syncrowave 200 ac/dc high frequency machine, will weld aluminum. Runs on 480 Volt Only. Single phase so it can be run off of a transformer powered by 220 household power. Uses only 2 legs of 480 3 phase." Is that possible (or true)? Report
June 10, 20179 yr comment_112441 Yes. 3 phase power is available as 3 phase 3 wire (delta) 480v, one of the phases is grounded so you have 480v between any two phases and 480v to ground. 3 phase 4 wire (Y) 277/480v has 480v between any of the phases but 277v to the grounded center point of the Y connected winding. These are the two most common types supplied by a utility. 480v is a very dangerous voltage as it will ionize the air when it faults and normally has the amperage available to cause a lot of damage and flash burns. Don't consider buying this one. Roly I am not sure but I do not think 480v is permitted in a residence. Edited June 10, 20179 yr by Roly Report
June 10, 20179 yr comment_112447 1 hour ago, Roly said: Yes. 3 phase power is available as 3 phase 3 wire (delta) 480v, one of the phases is grounded so you have 480v between any two phases and 480v to ground. 3 phase 4 wire (Y) 277/480v has 480v between any of the phases but 277v to the grounded center point of the Y connected winding. These are the two most common types supplied by a utility. 480v is a very dangerous voltage as it will ionize the air when it faults and normally has the amperage available to cause a lot of damage and flash burns. Don't consider buying this one. Roly I am not sure but I do not think 480v is permitted in a residence. Great information Roly, I love the knowledge base here. Report
June 10, 20179 yr comment_112450 2 hours ago, Roly said: Yes. 3 phase power is available as 3 phase 3 wire (delta) 480v, one of the phases is grounded so you have 480v between any two phases and 480v to ground. 3 phase 4 wire (Y) 277/480v has 480v between any of the phases but 277v to the grounded center point of the Y connected winding. These are the two most common types supplied by a utility. 480v is a very dangerous voltage as it will ionize the air when it faults and normally has the amperage available to cause a lot of damage and flash burns. Don't consider buying this one. Roly I am not sure but I do not think 480v is permitted in a residence. Utility company is never too happy when they see hook-ups like this. Report
June 10, 20179 yr Author comment_112451 Thanks Roly. It wasn't on my "buy" list, I had just never seen an electrical set up like that. Report
