April 21, 20179 yr comment_107017 I ran across an old post from somewhere else last night. I made a statement that the table saw was the most useful tool in my shop. Someone responded that he could do anything with his circular saw that I could do with my table saw. I also regularly see that, "Buy that [Festool] track saw and it will replace your table saw." Umm, I think not. I've always considered that a fantasy. After attending the joinery seminar last weekend and reading the cabinetmaking book I recently mentioned, it got me back on my soap box. I should note that I do have a sliding cross-cut table and a tenoning jig on my TS. I came up with a list of things I can do easily with a table saw that I couldn't do at all or with great difficulty and numerous jigs with a track saw: Cuts on edge or end of a board - tenons - bridle joints - slip joints - edge grooves (e.g., for a panel insert) - rabbets - joint variations such and tongue & groove, dado & rabbet, double rabbet joint, dovetailed rabbet, etc. - half lap - splined miters - keyed/feathered miters - box/finger joints - dovetails (yes, I've done them on a table saw) - Resawing (I've done this down to about 1/16") Any cut deeper than about 1.75" Operations using something other than a standard blade - dadoes and grooves with a dado set - molding head Bevels less than 45 degrees (or more than 45 degrees if you're using your tilt gauge) - raised panels - tapered slip tenon Operations on stock that's lot straight and square - mitering profiled moldings such as crown molding, picture frame stock (some of which might be compound miter) Other - cove cutting circular or elliptical - slab seat profiling (Mario Rodriguez: https://www.youtube.com/watch?v=5SveP71RLs4) - set up fence or stop(s) and "Measure once, cut 1000 times" - circle cutting - working on very small pieces (I can easily cut 1" off a 2" long, 1" wide board on my TS) </soapbox> Edited April 21, 20179 yr by kmealy Report
April 21, 20179 yr comment_107020 Not to mention the $$$ you need to spend for a tool that has limited use. Report
April 21, 20179 yr Popular Post comment_107021 Well, I have a track saw and anytime someone suggests it's a replacement for the TS I try to find out what they're smoking. It's like an RAS...a complimentary tool to the TS (IMHO). But I can tell you my track saw doesn't see "limited" use. I've found it really great for a number of things, Probably the most use is straight edging rough sawn lumber in prep for other machining. True, they are expensive, but I got mine when the Bing 25% rebate was going, and I slipped it through before Festool slammed the door on the Bing discounts. That said, it doesn't have to be a track saw, but a good circ saw with a well made guide will work, and cost a lot less. Report
April 21, 20179 yr Author comment_107024 32 minutes ago, lew said: Not to mention the $$$ you need to spend for a tool that has limited use. Not quite, but almost a "uni-tasker." I have a couple of shop-built and purchased guides for guiding my circular saw (or router). I use them a couple of times a year to break down sheet goods when I happen to be doing a project that starts with 4x8 sheets. Even then, I rough cut a bit over and get a finish cut on my table saw. Report
April 21, 20179 yr comment_107027 Not to take away from you but should this thread and others like it recently all go into the tools forum. Report
April 21, 20179 yr comment_107031 I would take the table saw over the track saw ant day hands down. Report
April 21, 20179 yr comment_107047 2 hours ago, Michael Thuman said: Not to take away from you but should this thread and others like it recently all go into the tools forum. Moved, thanks Michael. Report
April 21, 20179 yr comment_107052 I do not buy into the idea that a track saw can replace a table saw. I have both and I love and use them both, but each one has and knows its' place in the shop Report
April 21, 20179 yr comment_107062 There have been times when I wished I had a track saw, but it could never replace my table saw. Report
April 21, 20179 yr comment_107065 2 hours ago, It Was Al B said: There have been times when I wished I had a track saw, but it could never replace my table saw. Make one. Rip a piece of 3/4 apple ply about 10" wide and 8' long. Rout a dado approx. 2" from one edge, the size of some T track. That 2" is for clamping. Epoxy the track in. Cut a short piece of track insert, an inch longer than your circular saw's sole plate. Attach it to the sole plate. I was lucky. The Skil 77 had holes for the attachment. Your first cut establishes the cut line. Works like a charm. Report
