January 23, 20179 yr Popular Post comment_94014 I saved a narrow bandsaw blade in hopes of someday welding it back together. I have had this old Rockwell scroll saw sitting in my way for several years. After taking my tractor and pulling the big work table out of the shop, I moved the scrollsaw into line with the other machines. That is when I ran across the bandsaw blade. Looked at it for a moment, and decided to cut it to fit the old Rockwell. Surprisingly, it cut very well. Think I will hold on to the rest of the blade for future use in scroll saw! Haven't done anything worth sharing though. Report
January 23, 20179 yr comment_94033 That's a common suggestion over at OWWM. I used it once on an old scroller I had and it does work well. Report
January 23, 20179 yr comment_94142 That ought to work real good on 2x12" and bigger. The scroll saw blade makers might come a calling to your place with a gripe of hurting their business. Might snuf you out.. Report
January 26, 20179 yr Author comment_94637 Hey Patch, The main thing it to keep the main thing the "Main Thing!" If they snuff me, I am prepared and ready to leave this world anyway! Report
February 1, 20179 yr comment_95523 Hey Jim they won't let you go out before your regular time to go. You see they have you down for just a certain amount of taxes and it would screw up the whole system. Some president way back there came up with the New Deal, well this is the Raw Deal which actually its been going on forever but it works so smooth , even the guys that started it as the boat was coasting to a stop after they hit that rock. They were talking about something called a tax as the last man was getting off the flower. They got life rigged so no matter how hard you might try , you just won't be able to die before you supposed to. To prove it, say this guy died while drinking a glass of milk. It might sound strange but somebody in the crowd will say, well it was his time. Report
February 2, 20179 yr comment_95639 Years ago, when cost was reasonable, I had my saw blades sharpened by an old guy and he did a great job. I asked him if he repaired band saw blades. He said that he once did have a machine that re-welded band saw blades. The weld held really good, however, the blades had become brittle, due to heat and use. Once it broke, it was sure to do it again in another place. Report
February 3, 20179 yr comment_95845 On 1/31/2017 at 9:01 PM, Smallpatch said: Hey Jim they won't let you go out before your regular time to go. You see they have you down for just a certain amount of taxes and it would screw up the whole system. Some president way back there came up with the New Deal, well this is the Raw Deal which actually its been going on forever but it works so smooth , even the guys that started it as the boat was coasting to a stop after they hit that rock. They were talking about something called a tax as the last man was getting off the flower. They got life rigged so no matter how hard you might try , you just won't be able to die before you supposed to. To prove it, say this guy died while drinking a glass of milk. It might sound strange but somebody in the crowd will say, well it was his time. It really amazes me when they get a whole plane load of people together when it is their time to go. That has to take some real coordinating. Report
January 28, 20206 yr comment_216832 On 2/1/2017 at 9:40 PM, Ron Altier said: Years ago, when cost was reasonable, I had my saw blades sharpened by an old guy and he did a great job. I asked him if he repaired band saw blades. He said that he once did have a machine that re-welded band saw blades. The weld held really good, however, the blades had become brittle, due to heat and use. Once it broke, it was sure to do it again in another place. I agree with that 100%.... I have a blade welder. I have better luck silversoldering a band back together. The welder has an annealer to soften the blade up around the weld but it wont work with most band blade steels made today. Report
