December 27, 20169 yr comment_89691 Nothing exciting just sharing what is on my bench and what is going. I am trying to teach myself woodworking and hand craft. The attached photos are of box joints I am hand cutting. The box joint will be used in a drawer I am making for my table saw to catch the saw dust. In addition to this box joints, I had to make a jug to hold the work. Further, I sharpened up my tools. It is amazing how easy things are when tools are sharp. I sharpened my chisels to 2,000 grit wet-dry. Report
December 28, 20169 yr comment_89707 Alright ACR...great start both on the project and your PIP. Appears you've officially acquired the woodworking bug...sorry no vaccine or known cure...your best bet is continue therapy within this colony with the rest of us for a tip now and then how to control the illness. Clever solution with your jig too. I like it. Thanks for sharing Report
December 28, 20169 yr comment_89713 WOW! Getting those crisp edges on MDf means you really have the chisel sharpening down pat! Report
December 28, 20169 yr comment_89730 6 hours ago, lew said: WOW! Getting those crisp edges on MDf means you really have the chisel sharpening down pat! Cuts like butter. The joints are not perfect but it's a learning experience. Report
December 28, 20169 yr comment_89805 8 hours ago, ACR_SCOUT said: Cuts like butter. The joints are not perfect but it's a learning experience. I envy you! I myself am a perfectionist. Unless I can envision the entire procedure from beginning to end, I will not start it.To this day, I have never hand-cut a dovetail or box joint, because it MAY not turn out perfect! But the folks on this forum give me inspiration, and one of these days I WILL build a simple project using those procedures. The first one (or so) may well be firewood, though. John Report
