wilsonsmith Posted December 27, 2016 Report Posted December 27, 2016 (edited) Here are the two things you need to check weekly on your air compressor: Inspect Filters. If filters are clogged with dirt, your compressor won’t run efficiently. Clean or replace filters as needed for optimal performance. Inspect Belts. Look over belts for signs of wear like cracking or stretching. Replace as necessary Edited November 24, 2017 by Ron Dudelston tags added Stick486, Grandpadave52, Nickp and 1 other 4 Quote
p_toad Posted December 28, 2016 Report Posted December 28, 2016 I would add that if you have a "wet" compressor (it has a built-in oil bath), that you should check the sight glass before you use it...it's easy enough to do every time. Most of them will leak some (that I've seen). Miataguy 1 Quote
Miataguy Posted December 31, 2016 Report Posted December 31, 2016 Belts are really important, i check the ones at work regularly.... Quote
wilsonsmith Posted January 2, 2017 Author Report Posted January 2, 2017 On 12/28/2016 at 9:40 AM, p_toad said: I would add that if you have a "wet" compressor (it has a built-in oil bath), that you should check the sight glass before you use it...it's easy enough to do every time. Most of them will leak some (that I've seen). Thanks for the update p_toad. Its really a valuable point. Grandpadave52 1 Quote
wilsonsmith Posted January 2, 2017 Author Report Posted January 2, 2017 On 12/31/2016 at 11:16 AM, Miataguy said: Belts are really important, i check the ones at work regularly.... You also need to check the Filters Miataguy. It is also equally important as of the belts. Grandpadave52 1 Quote
