July 14, 201610 yr comment_67246 Hot and humid Wednesday here in south central Pennsylvania. We could use some rain here in the valley. Garden is getting dry. Speaking of the garden and some rain, here's a simple little turning project that you fisherman might be able to use. This thing is called a worm stick and is used for "Worm Grunting". The one pictured was not made on a lathe. Another one, I saw, had ridges turned on the vertical stick- an easy job on the lathe. Here's a link to information about this mystical process- http://journals.plos.org/plosone/article?id=10.1371/journal.pone.0003472 . There are several methods of "calling" the worms. The turned stick is just one type of instrument. I was perusing another turning site and came across this video discussing a technique called Shear Scraping. The author of the video- John Lucas- demonstrates the advantage of this method using a variety of turning tools. As for me, I finally had a chance to get to my lathe and make some shavings. We decided to take out the shrubs at the front of the house. They were here when I moved in so I know they were over 50 years old. Not sure what species they were but I can tell you they are completely unforgiving when you fall face first into them, from a ladder, while hanging Christmas decorations- don't ask. The piece I used was at the corner of the house. After chainsawing it out of the ground and doing some preliminary trimming, I ended up with- This is what was hiding inside- The turning is about 5" tall and 6" in diameter at the top. Sanded to 4000 grit. The only finish is paste wax. Totally impractical but I really like to make something from each tree/shrub we have had removed. Safe Turning Report
July 14, 201610 yr comment_67251 Lew thank you so much for taking the time to post these weekly reports. I love them. I find the outside links you provide are very interesting as well. And your pictorials are always fun to view. Thanks Lew! Report
