June 15, 201610 yr comment_66853 In this video I show how I install velcro backed sandpaper on my dual drum sander. I know a lot of you don't have drum sanders, but this will be good information for new owners of drum sanders that have not had to replace the sandpaper yet. For those that are looking at getting a drum sander, this will give you a good idea of what it is like to replace velcro backed sandpaper and might help you make a decision for yourself if this is a feature that you want or not. I share a lot of gold nuggets on installation and things to look out for. I hope you find this video helpful and informative. Your friend in the shop, Todd A. Clippinger Share the Love - Share the Knowledge Edited June 15, 201610 yr by Todd Clippinger Report
June 15, 201610 yr Author comment_66861 1 minute ago, lew said: Nicely done. The strapping tape is a neat idea. That is the way it came from the factory so I have just continued to follow their example. The timing was coincidental but perfect since John just bought his sanding machine. Report
June 18, 201610 yr comment_66885 Excellent video Todd. I am excited about getting mine. Had I seen this before I wouldn't have ordered the 60 grit paper. I used it all the time on cutting boards on the 16'x32' sander. So far the few pieces I have run through my new sander, I am very pleased with the results. Report
June 18, 201610 yr Author comment_66894 11 hours ago, John Moody said: Excellent video Todd. I am excited about getting mine. Had I seen this before I wouldn't have ordered the 60 grit paper. I used it all the time on cutting boards on the 16'x32' sander. So far the few pieces I have run through my new sander, I am very pleased with the results. So does it still come with 100 & 150 grits installed with the strapping tape on the ends? My recommendation certainly is based on my work and others may have a different opinion. The 80 grit is still pretty aggressive. I am looking forward to hearing of your experience. When it comes to changing grits, the biggest issue is the cloth backing separating from the sandpaper. This may not happen and I think it will depend largely on how much you have use the sandpaper. Since I have only ever ordered my sandpaper from Grizzly, perhaps there are other manufacturers that will not have this problem, such as Klingspor. I still keep in mind, there are a variety of factors that may vary, and you may be able to change grits. But as I stated in the video, I just wouldn't count on it. Report
June 19, 201610 yr comment_66908 Yes it came with 100 and 150 grit on it. I have run a few pieces through it and I'm very pleased with the results. Report
