September 11, 201511 yr comment_62440 I have this genetic thin skin on my forearms which causes me to bleed very easily when I bump into something or scrape against something. This is a real pain in the rear when woodworking as getting blood out of wood grain is not easy as well as having big red marks and scabs on my arms. When it is cooler I wear long sleeve shirts, but when it is hot during the summer it gets a bit rough. So after banging my arm yet again the other day I was rather annoyed and was debating about putting on a long sleeve shirt in the 90+ degree heat in the garage. Then it hit me and I thought about those compression sleeves that athletes wear to protect their arms as well as making them smoother with less friction against other players. So I headed over to my local Sports Authority store and picked up the cheapest pair I could find which was $9.99 (they have similar ones with logos of the big name companies all the way up to $30 but still the same materials). I have to say that I really like these sleeves as they are much cooler than wearing a regular long sleeve shirt and they fit very snug around the wrist so nothing dangling to get caught in a spinning bit or blade. Most important I didn't get my arms banged up. Edited November 25, 20178 yr by Ron Dudelston tags added Report
September 11, 201511 yr comment_62442 Cool tip, Allen, thanks.My biggest problem is banging my elbow into the live center on the lathe tail stock- even pulled all the way to the end of the lathe. Maybe I need to get a thick elbow pad for my right arm. Report
September 11, 201511 yr Author comment_62445 Lew, Back when I did a lot of turning, I had the same problem banging my elbow into the centers. I went to Home Depot and picked up some rubber caps that would fit over the ends of the centers and would put them on every time the wood was removed so I didn't hurt my elbow. If you put one of those strong round magnet disks inside the cap it will stick to the metal of the lathe so it won't fall off. You could also attach it to the lathe on a small chain so it will hang there in easy reach and not get lost. It only took me a a few short months to get to the point where I would do it automatically and not bang my elbow on it. Report
September 11, 201511 yr comment_62446 That's a cool idea, Allen! Thanks! I was just about ready to head out to Lowe's. I'll see what size I need for my centers. Report
September 11, 201511 yr comment_62462 Cool tip, Allen, thanks.My biggest problem is banging my elbow into the live center on the lathe tail stock- even pulled all the way to the end of the lathe. Maybe I need to get a thick elbow pad for my right arm.TAKE THE CENTER OFF~!!!!!!! Report
September 12, 201511 yr comment_62464 TAKE THE CENTER OFF~!!!!!!! TAKE THE CENTER OFF~!!!!!!! If I did that, I'd spend half a day looking for it the next time I needed it. I suffer from terminal CRS. Report
September 12, 201511 yr comment_62477 Ahhh I see. I am still working on my cure for that, and the cure has got a lot to do with the idea that if you give a tool a good home it'll usually find it's way there. I have the wall behind my lathe festooned with slanted boards into which I put holes or dowels etc and each hole or projection is a home for a particular one of those lathe items. Report
September 13, 201511 yr comment_62479 Cool tip, Allen, thanks.My biggest problem is banging my elbow into the live center on the lathe tail stock- even pulled all the way to the end of the lathe. Maybe I need to get a thick elbow pad for my right arm.Yep - me too Lew, or getting stabbed by a drill bit chucked up in the tailstock. Really smarts and since I am on blood thinner I bleed pretty good after that-again even with the tailstock pulled all the way back. Report
September 13, 201511 yr comment_62486 I have the wall behind my lathe festooned with slanted boards into which I put holes or dowels etc and each hole or projection is a home for a particular one of those lathe items. Ahh, the elusive wall space. I've read about that myth Report
September 15, 201511 yr comment_62495 I'm going to have to check that out Allen. The least little bump and I'm bleeding and then have an ugly red mark.Thanks. Report
August 25, 201610 yr comment_69486 I take blood thinner and just a little touch and I will start to bleed. I have been trimming trees for the last few days and this is what my arms look like. I am wearing gloves but I still get it. I can walk down the hallway in my home and my arm may hit a light switch and there is blood. I think your idea about the sleeves is a great solution for me. I have been taking blood thinners since 1986 and without them I hate to think what may be. When my wife and I go out I have to wear a long sleeved shirt! Again thanks for the great idea. Preston Report
August 25, 201610 yr comment_69491 My son works at the auto glass factory here in town ( AGC, Inc) and they are required to wear kevlar sleeves at all times while at work. Along with a pair of Kevlar gloves, BTW The Steel stamping plants that supply parts for the Honda Assembly plants around here, also have to wear those sleeves and gloves Might look into a source for the sleeves? Edited August 25, 201610 yr by steven newman Report
August 25, 201610 yr comment_69493 for blood thinner users get padded sleeves.. here.. made in Canada... http://www.superiorglove.com/arm-protection/protective-sleeves/cut-resistant-sleeves Report
August 25, 201610 yr comment_69576 Allen, Thanx for the info. I don't dare go into the shop or yard without gloves on due to thin skin on my hands. I'm guessing that the issue will migrate upwards over time. Rick Sexton Report
