July 7, 201511 yr comment_61150 Posed this on a couple of other places.. Ok, imagine that you are just starting out, and want to start woodworking, maybe as a hobby. Budget is very limited. You have no idea which tools to buy to get started. What sort of "list" would show what you need to start up with? Just the basic tool set. Some power tools MIGHT be added, if budget allows. Just to fill a common tool box that would be in the garage. Type of tool, and why? Have fun.... Report
July 7, 201511 yr comment_61151 When I started out, I had hand-me-downs from my father and grandfather so I didn't have a lot of choices. A hammer, hand saw, framing square, an old folder ruler and a brace and bit set. Those were enough because I was working with a carpenter building houses. Starting with those, these could be some of the more useful stuff to add- Combination Square Bevel Square Egg Beater Hand drill A 4-in-1 screw driver A set of twist bits Nail sets Stanley FatMax measuring tape. Swanson Speed square Utility knife with Irwin blades Extending magnet Flashlight A whole $h!t load of pencils Report
July 7, 201511 yr comment_61153 Yes, I completely forgot about a set of bench chisels, awe and plane. Report
July 8, 201511 yr comment_61173 Posed this on a couple of other places.. Ok, imagine that you are just starting out, and want to start woodworking, maybe as a hobby. Budget is very limited. You have no idea which tools to buy to get started. What sort of "list" would show what you need to start up with? Just the basic tool set. Some power tools MIGHT be added, if budget allows. Just to fill a common tool box that would be in the garage. Type of tool, and why? Have fun.... Framing Hammer Screwdriver Set Nail Set Combinaton Square framing square tape measure Carpenter's Saw Channel Lock Pliers A Couple of clamps chisels Coping Saw Plane Adjustable Wrench. Cordless Drill Motor-in the "olden days" I would've said an egg beater style hand cranked drill amd also would've said brace and bits. Drill Bits Report
July 9, 201511 yr Author comment_61195 I have been asked on another site about the "backstory" to this sort of post.... In this area, not only do we have a few disabled Veterans, we have young adults with learning troubles. I thought i could gather an inexpensive set of woodworking tools, make a case for them, and donate to whichever group might have a need for this. Maybe get a few interested in out craft enough to want to learn more about it. Yes, I said "DONATE" no auction to raise funds for me. No money for me at all. The tools are mainly "extras" that I have. Maybe make a carry case for them. make someone's day a little better. Now, IF others were to do the same thing in their own areas, maybe we can start something good for people? Report
July 9, 201511 yr comment_61201 When I started out, I had hand-me-downs from my father and grandfather so I didn't have a lot of choices. A hammer, hand saw, framing square, an old folder ruler and a brace and bit set. Those were enough because I was working with a carpenter building houses. Starting with those, these could be some of the more useful stuff to add- Combination Square Bevel Square Egg Beater Hand drill A 4-in-1 screw driver A set of twist bits Nail sets Stanley FatMax measuring tape. Swanson Speed square Utility knife with Irwin blades Extending magnet Flashlight A whole $h!t load of pencils I bought one item a week using my paper route money. Hammer, Framing Square, Screwdrivers - straight and phillips. Slip joint pliers.. Straight chisels. Adjustable wrench (monkey wrench style - not crescent wrench style looks like an "F"). Folding Rule. Tape Measure. coping saw. carpenters saw. Egg beater hand drill. Drill bits. Ratchet brace-and-bit (put it on layaway and paid some each week for a while). Bits for the brace -and -bit. Millers Falls Plane (also bought on layaway plan). Vise. Combination square. Then on to the power tools: Sunbeam Drillmaster 1/4" drill motor. Skill Saw. Dunlop 12" 3-wheel Band Saw. Craftsman Lathe (Dunlop had bronze headstock bearings - Craftsman had ball bearings. Craftsman also had an available bed extension). Lathe Chisels. Lathe tooling (bed extension, drill chuck, 4-jaw chuck, Work arbors screw center, outboard faceplate. Sanding disk, L-shaped tool rest) weird Drill Press that used a 1/2" drill motor which could be removed from the drill press and used as a hand held drill motor. I wanted a shop in the basement and I paid for it myself. Sort of trying to prove to my Father that I could have a hobby that I paid for and he didn't have to . Report
July 9, 201511 yr Author comment_61208 Ok, tool box was delivered today. RTC IND. of Logan County, OH. They serve people with disabilities through out the county, regardless of age. The gal behing the counter when I walked in RAN out to meet me! I had called ahead to make sure they'd take it. Couple photos of what went out there today. . Somehow had to get all of this to fit.....the saw got changed out, was about 4" too long About full? well, there was a lift out tray, as well. And this is almost all that landed in the tray. . There was also a 12" F style clamp to lay on the tray. I have the entire table of contends, IF anyone wants to read through it. Lots of tools in one place.. There is even a #3 sized plane, and a block plane in the bottom of the black plastic tool box. Chose that so the box would last longer. There is a way to pad lock the box as well. Just in case.... They said they will be sending me a nice THANK YOU note in the mail.....this entire box was a donation nothing more... So, anyone want a list? It is a LONG one.... Report
July 9, 201511 yr comment_61213 After that donation, you're going to have to do a lot more rust hunting!!! Report
July 11, 201511 yr comment_61263 a JAPANESE SAW, BRACE AND A SET OF BRAD POINT BITS TAPE MEASURE COMBINATION SQUARE, HAMMER, BAILEY PLANE STANLEY CHISEL SET, PIN PUNCH SCROLL SAW UTILITY KNIFE COMPASS WITH PENCIL CARPENTER AND REGULAR PENCILS, PAD OF PAPER WOOD GLUE PACK OF FINISH NAILS (ASST. SIZES) THAT'S ALL i CARRY. (AND OF COURSE THE CORDLESS IMPACT AND DRILL.) Report
