May 11, 201511 yr comment_60419 I'm having a problem with fisheyes in a top I'm finishing. I am using a wipe on poly and have tried wiping down with paint thinner, mineral spirits and, washing the clothes I'm using to make sure there is no fabric softener. This is driving me crazy, am I missing anything? Should I try wiping down with denatured alcohol ? Report
May 11, 201511 yr comment_60420 May be something in the wood. Try sanding it back down and using a coat of clear shellac. Dries really quick and can be sanded then apply your poly. Report
May 11, 201511 yr comment_60422 Definitely re-sand. If the piece has had finish applied before you may have to sand deeps spending on the type of finish. If you're using wipe on poly, I'd suggest applying the poly with a new piece of pantyhose. New because you don't want any body oils or soap in them. Cut a piece about 6-8 inches long and fold it twice. Makes perfect applicator. Good luck! Report
May 11, 201511 yr comment_60425 Charles, what type of wood is the top, and is this a refinish job or new? Report
May 16, 201511 yr Author comment_60460 Thank you everybody for you suggestions. The item I am working on is a top for a desk my son and I are making. The top has 2 beautiful 4 way book match of blackwallnut with a 2 1/4" wide x 1 1/4" thick AM cherry border. The next one we will be working on is his. Yes I am using wipe on poly and the can is new. Ron thanks for the idea of using the pantyhose and I think I'll put a cotton cloth inside so it can hold more finish the top is fairly large. The cotton clothes I have been using have been washed then they went threw a second wash with no soap or softeners. Wayne thanks for the suggestion of the shellac but It can leave blotch and problems if your not careful and with a large area and the quick drying it can be challenging.I just don't have the experience with it to try it. I already have sanded it down again so I'll let everyone know what happens ok and thanks again Report
May 16, 201511 yr comment_60461 Keep us posted. Can't wait to see how it turns out so post a picture when you're finished. Report
May 16, 201511 yr comment_60462 Working with veneers, you only have few more shots at this Charles before you sand through! Report
May 16, 201511 yr comment_60463 I'm looking forward to seeing it when done as well. I have never heard of this issue before, but then my experience is limited to wood turning and finishing (no flatwork). Report
July 11, 201511 yr comment_61270 Nobody mentioned applying a finish too heavily. That can cause fish-eyes too. With a wipe on poly it's unlikely to get it on so heavy, but its a cause that's goo to know about When re-finishers get fish-eyes they usually credit to to things like Pledge which all have silicone in them Some guys use a treatment for them that just contaminates their whole system with silicone. 'Coz that's what it is - - more silicone. Other guys hit it with light applications of heavy weight cut sprayed shellac ( from a distance so it's mostly dry when it lands) in as many coats as it takes to get on top of the fish eye and seal it underneath and - quick like a bunny before it can migrate up - the final top coat. Report
August 25, 201610 yr comment_69583 Fish eyes can also be silicone contamination. If you ever used pledge then you are out of luck. I know of no solvent that can break down silicone the silicone transfers to the sand paper quite well then redeposits its self in random places. Did the sanding work? Report
August 29, 201610 yr comment_70603 On 7/11/2015 at 10:55 AM, Cliff said: When re-finishers get fish-eyes they usually credit to to things like Pledge which all have silicone in them Some guys use a treatment for them that just contaminates their whole system with silicone. 'Coz that's what it is - - more silicone. Other guys hit it with light applications of heavy weight cut sprayed shellac ( from a distance so it's mostly dry when it lands) in as many coats as it takes to get on top of the fish eye and seal it underneath and - quick like a bunny before it can migrate up - the final top coat. +1 on this. When I refinish, I can generally tell by the way the stripper sits if it's silicone contamination from Pledge or spray silicone lube. I do not allow silicone in my shop. I don't even use "Fish Eye Preventer" as it's just more silicone -- the hair of the dog that bit you, if you will. . I say silicone is like herpes -- once you have it, you'll never get rid of it. Strippng, sanding, wiping down -- none of it works if the piece is contaminated enough. If any doubt, I spray on a couple of coats of de-waxed shellac (e.g., SealCoat) before I put any finish on. Stains don't seem to be bothered by it. Edited August 29, 201610 yr by kmealy Report
August 30, 201610 yr comment_70882 Thanks for the tip I would use a 1# cut of shellac in my sprayer what do you use? Report
September 1, 201610 yr comment_71271 I spray Zinsser Seal Coat ( 2# cut dewaxed shellac) in a cheap $12 Harbor Freight sprayer. I have one that I have just marked for shellac. I just go straight from the can. Report
September 1, 201610 yr comment_71309 4 hours ago, kmealy said: I spray Zinsser Seal Coat ( 2# cut dewaxed shellac) in a cheap $12 Harbor Freight sprayer. I have one that I have just marked for shellac. I just go straight from the can. What size tip are you using? Report
September 1, 201610 yr comment_71317 Ummm, whatever comes with the gun, I'd have to unpack it and see. The tech specs and manual does not say. They include a generic tip size for viscosity chart, but don't say which one is standard. http://www.harborfreight.com/20-oz-high-volume-low-pressure-gravity-feed-spray-gun-47016.html I have one for shellac, one for NC lacquer and another for w/b spray stains. At $12-15 it hardly makes sense to even clean them sometimes. ;-) Report
