3m Bristle discs for angle grinder
Got some for  some hot water radiator covers I have that need  cleaning up.
 Spent more than I wanted, but took a chance Those things are not cheap.
Anyway They are GREAT~!!
They don't load up, they don't burn, they don't get dirty. They are like new each time I  present them to the work.  It's like they are fresh out of the package  no matter how I use them on layers and layers of paint  and rust.
I haven't worn one out, but I'm going to try.
Edited by Ron Dudelston
tags added
From EASTWOOD
Qty Item Description Amount
 31128 Bristle Disk 4 1/2 in 50 grit Green
 13198 Bristle Disc Yellow 80 Grit 4.5 IN
yeah on soft stuff(copper, aluminum, brass, tin a light touch and they do great!!!
Cast Iron I still prefer the wire cup brushes though.
I'm using 'em to strip  years of paint from sheet steel fin type radiator covers.  The nicest thing abut is they don't  load (not a smidge) with the old paint.  They are fresh as a daisy each time & the whole time.
  • 1 month later...
A while into using these things.  I gotta say.  They don't do a better job of descaling  steel or removing weld splatter  than a cheap flap disk. They are slower. but they won't gouge.
