March 2, 201511 yr comment_59046 When painting some of the small toys I make, no matter how smooth I get the end grain it seems to soak up the paint. I some times spray an extra coat of primer with not much better results. I guess my question is what about using sanding sealer or "pre-stain conditioner"? Thanks. Report
March 2, 201511 yr comment_59047 Zinsser Seal Coat is a shellac based sealer that I use. It comes in clear and amber. A coat or two with a light 400 grit sand to knock off the nibs and your ready to go. The stuff runs about $35 or do a gallon at the big box store. Report
March 2, 201511 yr comment_59049 Not sure about painting, but for staining- sanding the end grain to a finer grit than used on the rest of the project will help keep the stained end grain the same color as the "flat" sides. Report
March 2, 201511 yr comment_59050 One more thin about Seal Coat. Be sure to buy the de-waxed shellac. Report
March 3, 201511 yr comment_59053 KIDS TOYS ALERT!!!!!!! They make the spray by krylon in clear so that all it is is the paint WITH NO PIGMENT in it. safe for kids. Use that and keep spraying it till it quits absorbing it. Report
March 5, 201511 yr comment_59153 To make the end grain smooth, Lew is correct, go a grit above way the rest of the project has been sanded with. Also sand between coats on the end grain and you might have to put an extra coat on the end. Report
March 14, 201511 yr Author comment_59324 Thanks for all the in-put. I'll play around some and see what happens. Report
