February 20, 201511 yr comment_58761 ....all 2" long and 1/2" wide and most 2.5" deep. Use a drill press to hog out most of the wood and use a chisel? Router not really a good choice for the deeper mortises. The heck with all that. After much online research and lots of inner debate, and consultations with the war dept., I pulled the trigger on the Delta stand alone hollow chisel mortise machine. Review will come after first use. Report
February 20, 201511 yr comment_58762 Good Choice! I have an old Bridgewood one (similar to Grizzly) and it still works great. While you're at it, buy the cone sharpening stone for the chisels. Report
February 20, 201511 yr comment_58763 . The heck with all that. H HA HA HA HA HA HAH AH AH AH A HA HA HAHAH AHAH AHAH HAHAHAHAHAHAHAHAAAAAAAAAAAA Yah - - - I'd a got mesef a moOoOOoticer too To me makin' dem MoOoOo-Tices You actually order it yet? If not consider loose tenons. Report
February 20, 201511 yr comment_58764 ....all 2" long and 1/2" wide and most 2.5" deep. Use a drill press to hog out most of the wood and use a chisel? Router not really a good choice for the deeper mortises. The heck with all that. After much online research and lots of inner debate, and consultations with the war dept., I pulled the trigger on the Delta stand alone hollow chisel mortise machine. Review will come after first use. Congrats Gene! Report
February 20, 201511 yr Author comment_58766 Lew, Ordered them, too. Everything I've read suggests that sharpening the new chisels before their first use will be beneficial. Cliff, I'm making 4 sets of Morris chairs and ottomans. For most all of my M&T work in the past, I've used loose tenons. But, these require through tenons. Integral tenons would be less hassle. Report
February 20, 201511 yr comment_58777 Congratulations. I think you will love it. Mine is a Craftsman and it does a really good job. I enjoy having the dedicated machine for it. Report
February 20, 201511 yr comment_58781 Good call Gene. My mortising machine came complements of my son who made two Morris chairs and bought the machine. When you get it give me a call. I'll show you a quick sure fire way to set your drill depth. Report
February 21, 201511 yr comment_58789 Congrats Gene. I'm still doing mine by hand but 72 is a lot of M+T. Looking forward to your review. Report
February 21, 201511 yr comment_58791 , I've used loose tenons. But, these require through tenons. Integral tenons would be less hassle. I use loose tenons exclusively. Never done one that goes through. Thought about it, but never have. Method: * I put the stock on my slot mortiser and make the pocket/slots. * I run some stock through my TS then the planer and if I really care about edge fitting (I used to, but don't any more) I can fit them to the pockets on the router table with a roundover bit. I really like the ability to control the fitment of the tenon to the pocket/slot to within a lousy couple of thousandths of an inch so I cam make 'em as tight as I please and the planer lets me do this. I don't see why I'd need to go through. What method is it that locks you into through tenons? Report
February 21, 201511 yr Author comment_58796 Thanks, Ron. I'll do that. Cliff, Nothing locks me in to through tenons. The G&G style and these plans call for exposed through tenons. I've seen and/or read recommendations to use stub tenons and fake the exposed portion with an inlaid piece. Way more work than just building a through M&T to begin with. And, I'm really not enamored of a "Morris Chair" sans exposed M&T joints. Just a personal bias, I guess. Report
February 23, 201511 yr comment_58845 Thanks, Ron. I'll do that. Cliff, Nothing locks me in to through tenons. The G&G style and these plans call for exposed through tenons. Oh. I see. Took me a minute. Report
