November 14, 201412 yr comment_56130 Here is my gizmo to make my PM 3520B lathe go slow slow slow It's an old salvage gear-motor and a little shaft I made that slips over the gear-motor's shaft with a couple of grooves cut in it that accept sewing machine bobbin drive rubbers Report
November 15, 201412 yr comment_56131 Neat idea, Cliff! Aside from applying finish, what other cool applications have you come up with?? Report
November 15, 201412 yr Author comment_56133 Aside from applying finish, what other cool applications have you come up with?? Self hypnosis, Sanding, you are getting sleeeepy Report
November 15, 201412 yr comment_56134 For sanding, are you using a sanding disk/ball on a power drill while the work piece rotates?? Also, can you reverse the gear drive rotation? Report
November 16, 201412 yr Author comment_56159 Not reversible unless I move the motor or use the VFD on the lathe. Sanding is powered VIA a pneumatic drill with these little PSA 3" discs of various grits. The dayton gear motor and rubber dubbers driving the hand well provide a surprising amount of torque: enough to let me lean pretty hard while sanding. Nice thing about going really slow is that when I get to the interrupted edge of a live edge or other interrupted surface I am not bounced all over the place. Report
November 16, 201412 yr comment_56160 Man that works like a charm!! You must a have a really nice air compressor, too! Report
November 16, 201412 yr Author comment_56163 it's just a cheap campbell hausfield air drill I got at an auto parts store maybe 20 years ago. At first I was using a Milwaukee (USA made) electric drill. I put it down and when I picked up a day later it made a huge puff of sawdust fines when I turned it on. That was the last time I used a drill for that. The silica in the fines can't be good for any part of the drill. The air tool was in my mechanic's tool kit and I prefer it now because it doesn't suck up dust fines. It blows air out. Report
November 17, 201412 yr comment_56164 Wow, that is really inspiring Cliff, beside the actual slow speed attachment, what type of wood is that bowl made from and how are you coming along with turning in general, seems like you are moving light speed with this turning stuff! Report
