October 17, 201412 yr comment_55561 Ok, got the last of the rebates cut. Made a few nicely curlies with that homemade plane. Started to put things together Pinned and wedged a few joints, usinf the draw-bore way. Pins would tend to wander off line a bit, and blow out the other side. Oh well, will be a PAINTED door. Some Titebond III and some sawdust, then sand smooth Worked my way from one long rail, across to the other long rail. Pipe clamps to pull things tightly into place, then a glue covered pin to hold it there. FINALLY got this thing together, and stood up in the shop This be the bottom half. Door is at the far end of the shop, with the camera at the other end. And a look at the top half Next up? Some filler, some Kilz Primer (2 coats) hang the door, and maybe add a top coat. Oh, and install a latch.... Already discussing a new door to go with it, re-using the old window from the old door.....Another story, one door at a time... Report
