lew Posted September 12, 2014 Report Posted September 12, 2014 My brother and his wife asked me to build them a “remote caddyâ€. My first reaction- No Problem! But, again, I think I allowed my mouth to override my butt. This is the design they wanted. It is about 4â€W x 6â€L x 4â€H. I thought, I could create the layers- with holes- and them glue them together. I made mine of Oak, Maple, Walnut and Cherry. I measures about 4†x 6†x 5â€. Finish is oil based poly. I ended up making a jig to cut out the holes. Rough cut the holes using my scroll saw. Then used the jig to rout to holes to the final dimensions. The router bit was a spiral flush cut bearing bit. This bit worked so much better than the straight cutting pattern bit I first tried. Less burning and a smoother cut. A finished piece- The pieces were cut over sized to be able to better fasten them to the template. I tried double sided sticky tape but that didn't hold. I ended up using pin nails around the perimeter. Then trimmed the pieces on sliding table jig- Once all of the pieces were cut, I had to figure out how to keep them aligned during the glueup process. Ended up making an alignment key from a scrap of poplar. I waxed the surface heavily to keep glue from trapping it. A test fit- In the clamps- Then some final sanding and the finish. If I had it to do over, I would have used lacquer instead of poly. The poly tinted the maple a golden hue. I was thinking white strips. Thanks for looking! John Moody and Harry Brink 2 Quote
John Moody Posted September 12, 2014 Report Posted September 12, 2014 Wow, wow, wow. That is awesome and a nice process to build them. I like the idea of the key to keep them in line. Quote
Gene Howe Posted September 12, 2014 Report Posted September 12, 2014 Way to go, Lew. Great job and a very helpful pictorial. Color looks real good from here. Quote
lew Posted September 12, 2014 Author Report Posted September 12, 2014 Thanks for the kind words, Guys, they are really appreciated! Quote
Ron Dudelston Posted September 12, 2014 Report Posted September 12, 2014 I knew you cold do it Lew. It looks great! Quote
Cliff Posted September 13, 2014 Report Posted September 13, 2014 Sweet~!! nice way to overcome the design issues Quote
Ron Dudelston Posted September 13, 2014 Report Posted September 13, 2014 Lew, are you going to make these to sell or are they too labor intensive? Quote
lew Posted September 13, 2014 Author Report Posted September 13, 2014 Lew, are you going to make these to sell or are they too labor intensive? I guess they could be sold- the original picture of the one on the Internet sells for $60+ and I understand why. I don't think I'll add these to the rolling pin line. Quote
