February 18, 201115 yr comment_49287 Any body knows name of putty that will actually blends or match the stain? I'm not sure but I seems to remember Ralph may have found one about a year or so ago. I thought I had it written down but can't find it. Did a sample on staining a scrape white oak with several putty I had and they are showing thru like a sore thumb. Yea I made an oops on the bookcase. But then it been awhile since done made something like this. Would appreciate any help. thanks Wayne   Report
February 19, 201115 yr comment_49291 This stuff isn't too bad http://www.timbermate.com/ What color stain are you using? How big is the hole? Got any pics? Report
February 19, 201115 yr comment_49290 Good Morning Wayne,The wood filler I use is call Timber Mate that can be bought at Woodcraft stores or over the internet. I use it all the time for it will accept stain very well and once stained and finished you can hardly tell where it is. I now buy it by the quart and every so often I simply put a few drops of water on the top and close the lid and it all stays nice and soft. No mixing or fuss but don't use a metal putty knife for it turns the wood black and is hard to get out. Report
February 21, 201115 yr Author comment_49289 dragon1 said: This stuff isn't too bad  http://www.timbermate.com/   What color stain are you using?  How big is the hole?  Got any pics?  Dragon  The stain my son wanted is Natural made buy MinWax. It really nothing more of a clear stain but it does seems to tint the white oak to a slightly reddish brown. The only place I really needed to use the putty was just under the top and at back inside corner of the bookcase where I did a rabbit cut for the top with the router. What happens was the clamps that I had in holding an straight edge for the router slips at one end and the bit dug in little more than i wanted. You would hadve to look in under and upside down to see it. Did 2 coats of stain and think that may be it. Am planing on applying at least 3 coats of lacquer may do 4 coats but will see how 3 looks. But it be thursday before I can get back to it. Will get some pics on it. Thanks for the name of the putty. I'll see if I can get some try it.  Wayne  Report
February 21, 201115 yr Author comment_49288 Ralph Allen Jones said: Good Morning Wayne, The wood filler I use is call Timber Mate that can be bought at Woodcraft stores or over the internet. I use it all the time for it will accept stain very well and once stained and finished you can hardly tell where it is. I now buy it by the quart and every so often I simply put a few drops of water on the top and close the lid and it all stays nice and soft. No mixing or fuss but don't use a metal putty knife for it turns the wood black and is hard to get out.   Ralph  I thought it was Timber something but could not remember for sure or where to find it.  Think I will get some. Can you use a plastic putty knife? Think I have one but maybe little wide which I maybe able to trim it down.  thanks  Wayne Report
