May 5, 201115 yr comment_46002 1 1/2 HP Black Decker Router Cat No. 7614 Type 1, 25000 RPM, 9.0 AMPS, 120 volts  I found the router in my dad's toolbox. I test and it run good but I am trying to figure how to change bits. It comes with little wrench but seems its for something else. Do you know what size or kind wrench I need to loose and remove bit so I can test with other bits.  I looked Google for manual but can't find anything for this kind tool. Maybe there's video how to do it? Sorry, I am still learning....smile!  See pics attached.  Please advise.  Report
May 5, 201115 yr comment_46020 Grant, you can use any wrench that fits. It might have a shaft lock which is a small metal piece that locks into the collet area. You then only need 1 wrench to release the nut. If it does not have a shaft lock, you will need 2 wrenches. 1 to fit the collet nut and 1 to fit the shaft. I have used mechanic's wrench and adjustable wrenches, any port in a storm. Report
May 5, 201115 yr Author comment_46019 Bob, Thank you!! What about bits size? I've seen some at store, is router bits fit all kind of router including mine? Report
May 5, 201115 yr comment_46018 Looks like a 1/4 inch router bit. Take the bit out and measure the shaft. That metal piece going across (3rd pic.) locks 1 nut and the wrench turns the big one. Report
May 5, 201115 yr comment_46016 If it is like mine, it takes a 15/16ths open end wrench.   There should have been a thin (almost useless wrench that slides into the base of the router. yep. router bits with a 1/4" shaft. Report
May 5, 201115 yr comment_46015 I have this exact same router. It uses 1/4" shank bits, the shaft lock is shown in the 3rd pic and you push the lever into the shaft while turning the wrench. Steven is correct it's a 15/16" wrench. I think I have the manual, I'll look and if I have it I can scan it and e-mail it to you. I should be able to send it in a couple of days. Report
May 5, 201115 yr comment_46014 Grant I found the manual and I'll scan it tonight at work and can probably send it to you shortly after, just send me an e-mail address. Report
May 6, 201115 yr Author comment_46013 Guys, I went to Home Depot and Lowe's and they both do not have that 15/16" thin wrench. I guess I will have to call Black & Decker and see if they sell it? Unless you know any specialty store that sell it? (rockler or woodcraft?) John, I would love to have manual -- appreciated it! Send it to grantlairdjr@gmail.com Report
May 6, 201115 yr comment_46011 Hey Grant, how quick do youi need it? I think I have 3 or 4 of them if you can wait. No charge just let me know if you want it. Every time I buy a router I get one and I have like 6 routers. Report
May 6, 201115 yr Author comment_46010 Ron, I am in no hurry -- I would love to have one!! Â If so, I can send you private message and give you the address. Smile!! Report
May 6, 201115 yr comment_46008 Grant you should now have the manual in your e-mail. I sent it as a PDF file. Report
May 6, 201115 yr comment_46006 If your interested I could send you the router Ive go, I don't use mine any longer and it's in good shapet, you may need parts for yours. Report
May 6, 201115 yr Author comment_46005 Mike, yes that would be nice, too! I was reading manual and notice router lve but I don't have it, either. Report
May 11, 201115 yr Author comment_46004 Ron send me the spare wrench for this router and it works! I am very grateful for wonderful people at this website including Mike for sending me manual PDF!!Just want to say THANK YOU! Report
May 11, 201115 yr comment_46003 You hit the nail on the head Grant, we have some great folks here. We are small site, but we have a lot of heart. Thanks for being here Grant Grant Laird Jr said: Ron send me the spare wrench for this router and it works! I am very grateful for wonderful people at this website including Mike for sending me manual PDF!! Just want to say THANK YOU! Report
