June 13, 201115 yr comment_44663 Does anyone have a good line on ring inserts for jewelry boxes or drawers? I have found some when I Google them, but nothing I can use, any body know of a good supplier? You know those felt or vevety liners that you stand up rings in when you open the drawer of a jewelry box?Thanks! Report
June 13, 201115 yr comment_44665 JohnYou can make your own. Simular to the coin display caases. Score your insert piece wide enough to fit the rings then use flocking to cover it.The ones that are ready made that I have seen are pretty pricey and the quality was not all that high. For thinner rings use can use 1/8 grooves and the thicker bodied rings 3/16 grooves. Hope this helps. Wayne God Bless our Troops and Protect them. Report
June 14, 201115 yr Author comment_44664 Wayne, that's great idea, thanks! Wayne Mahler said: John You can make your own. Simular to the coin display caases. Score your insert piece wide enough to fit the rings then use flocking to cover it.The ones that are ready made that I have seen are pretty pricey and the quality was not all that high. For thinner rings use can use 1/8 grooves and the thicker bodied rings 3/16 grooves. Hope this helps.  Wayne God Bless our Troops and Protect them. John MorrisThe Patriot Woodworker Report
