June 23, 201115 yr comment_44295 Anyone know of a place I can purchase hangars and such for jewelry boxes? I want to install a rotating necklace hanger in my clock case I am converting to a jewelry case. Thanks in advance! Report
June 23, 201115 yr comment_44305 John, I googled Jewelry Store fixtures and here are a few I came up with. http://www.displays2go.com/Category.aspx?ID=24806 http://infinitystorefixtures.com/ http://www.triodisplay.com/catalog/jewelry-store-c-2539_2758.html They may have something you are looking for or if you contact them, they might be able to put you on the right place.    John MoodyJohn Moody Woodworks Report
June 23, 201115 yr Author comment_44303 YES! But wheeedoggy! They are expensive! John MorrisThe Patriot Woodworker Report
June 23, 201115 yr Author comment_44302 Might have to make my own. Hmmmmm John Morris said: YES! But wheeedoggy! They are expensive!John MorrisThe Patriot Woodworker John MorrisThe Patriot Woodworker Report
June 23, 201115 yr comment_44301 Just cut a disk from 3/4, drill holes around the perimeter and band saw them open. Round over both sides, including in the opened holes.Counter bore the bottom center for a 1/4-20 bolt and washer and plug. Get a 1/4 id  brass sleeve to cover the threads. Cut a smaller disk.  Round over the perimeter. Could profile it, if you want. Counter bore for a nut. Run the sleeve onto the bolt.Put the end of the bolt through the small disk. Apply Loctite and bolt it all together. Glue in the plug. Glue the small disk to the underside of the top.The Walnut jewelry chest in my pics has a hanger made that way. Works fine. Report
June 23, 201115 yr comment_44300 Some of the first places that pop into mind, Lee Valley and McFeelys.They both have a wide assorment of all kinds of small parts. Wayne God Bless our Troops and Protect them. Report
June 24, 201115 yr comment_44299 Woodcraft stores stock everything you are looking for. If there isnt one close to you, they have a great website. Just google them for a store locator. Good luck! Report
June 25, 201115 yr Author comment_44298 Thanks Gene, great idea, if I don't find one reasonable priced, I'll use your idea, that will work great. Gene Howe said: Just cut a disk from 3/4, drill holes around the perimeter and band saw them open. Round over both sides, including in the opened holes. Counter bore the bottom center for a 1/4-20 bolt and washer and plug. Get a 1/4 id  brass sleeve to cover the threads. Cut a smaller disk.  Round over the perimeter. Could profile it, if you want. Counter bore for a nut. Run the sleeve onto the bolt.Put the end of the bolt through the small disk. Apply Loctite and bolt it all together. Glue in the plug. Glue the small disk to the underside of the top. The Walnut jewelry chest in my pics has a hanger made that way. Works fine. John MorrisThe Patriot Woodworker Report
June 25, 201115 yr Author comment_44297 Right on Wayne! I never thought of McFeelys and I forgot about LV's! Wayne Mahler said: Some of the first places that pop into mind, Lee Valley and McFeelys. They both have a wide assorment of all kinds of small parts. Â Wayne God Bless our Troops and Protect them. John MorrisThe Patriot Woodworker Report
June 25, 201115 yr Author comment_44296 Hey Adam, I could only find one on the Woodcraft website and it was the same brass one mentioned earlier in this post. I thought WC would have had a ton more stuff, unless I am not looking in the right place. I'll try again and thanks. Adam Welker said: Woodcraft stores stock everything you are looking for. If there isnt one close to you, they have a great website. Just google them for a store locator. Good luck! John MorrisThe Patriot Woodworker Report
