October 3, 201115 yr comment_40107 WOOD probably won't like me stealing Paladin's post, but it's just too good not to share with the Gang here.I've BTDT BIG time! How about you?Larry DRILL PRESS: A tall upright machine useful for suddenly snatching flatmetal bar stock out of your hands so that it smacks you in the chest andflings your beer across the room, denting the freshly-painted projectwhich you had carefully set in the corner where nothing could get to it.WIRE WHEEL: Cleans paint off bolts and then throws them somewhere underthe workbench with the speed of light. Also removes fingerprints andhard-earned calluses from fingers in about the time it takes you to ay,'Oh sh --'SKILL SAW: A portable cutting tool used to make studs too short.PLIERS: Used to round off bolt heads. Sometimes used in the creation ofblood-blisters.BELT SANDER: An electric sanding tool commonly used to convert minortouch-up jobs into major refinishing project.HACKSAW: One of a family of cutting tools built on the Ouija boardprinciple. It transforms human energy into a crooked, unpredictablemotion, and the more you attempt to influence its course, the moredismal your future becomes.VISE-GRIPS: Generally used after pliers to completely round off boltheads. If nothing else is available, they can also be used to transferintense welding heat to the palm of your hand.TABLE SAW: A large scarry stationary power tool commonly used to launch woodprojectiles for testing wall integrity.BAND SAW: A large stationary power saw primarily used by most shops tocut good wood stock into smaller pieces that more easily fit intothe wood stove, after you cut on the inside of the line instead of theoutside edge.TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength ofeverything you forgot to disconnect.PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lidsor for opening old-style paper-and-tin oil cans and splashing oil onyour shirt; but can also be used, as the name implies, to strip outphillips screw heads.STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used toconvert common slotted screws into non-removable screws and butcheringyour palms.HAMMER: Originally employed as a weapon of war, the hammer nowadays isused as a kind of dimpler so you can use wood filleradjacent the object we are trying to hit.UTILITY KNIFE: Used to open and slice through the contents of cardboardcartons delivered to your front door; works particularly well oncontents such as exotic wood veneer, vinyl records, liquids in plastic bottles,collector magazines, refund checks, and rubber or plastic parts.Especially useful for slicing work clothes, but only while in use.S.O.B. TOOL: Any handy tool that you grab and throw across thegarage while yelling 'S.O.B.' at the top of your lungs. It isalso, most often, the next tool that you will need.~PALADIN~Wood'nBoats&Stuff Report
October 3, 201115 yr comment_40118 Larry, what is BTDT stand for. I must be getting old! I have seen this before, pretty cool, it has a serious ring of truth to it, I think we can all relate to at least a few of these situations Hey Larry, I have a good post I'd like to share over on WOOD that originated here on TPW, do you think they'd appreciate that Thank God for TPW, site of the free, and home of the rebel woodworker! Â Â John MorrisThe Patriot Woodworker Report
October 3, 201115 yr comment_40117 I saw this somewhere before. Is Paladin the original author of this? I'm with John, what is BTDT? John MoodyJohn Moody Woodworkshttp://www.johnmoodywoodworks.com Report
October 3, 201115 yr comment_40116 Been There Done That, and no, you don't get a WOOD T-shirt out of it.  'and may the road raise up to meet ye' Report
October 3, 201115 yr comment_40115 John1.. Don't think ole Matt would allow it. He'd run to Marlen. John2.. I don't know if Paladin is the Author. I rather doubt it. I think I saw this along time ago too. Report
October 3, 201115 yr comment_40114 BTDT????Matt's a good ol boy, I got no beef with him. Matter fact, I got no beef with anyone. I am just a happy clam in the pond. Life is good, WOOD is good, the members are tops, and so are ours. We both have our respective areas to stay in, and that my friend is a friendship made in heaven! John MorrisThe Patriot Woodworker Report
October 3, 201115 yr comment_40113 Marlen was trying to get a hold of you. That's why I asked you for your phone number. Be happier.. call him. You'll like it. Larry Report
October 3, 201115 yr comment_40112 Bygones be bygones Larry, nuff said, time to move on sir. Larry Jenkins said:Marlen was trying to get a hold of you. That's why I asked you for your phone number. Be happier.. call him. You'll like it. Larry John MorrisThe Patriot Woodworker Report
October 3, 201115 yr comment_40110 Thanks Larry, but I respectfully bow out of this one. Ties are cut, no hard feelings, it just is what it is. So back to Paladins post, way cool, I can definitely relate to the screwdriver, dang can can't open, but the palm of my hand sure opened up when it slipped!Larry Jenkins said:His intentions are not what you think. John MorrisThe Patriot Woodworker Report
October 3, 201115 yr comment_40109 Your choice, John. I do know that Marlen wanted to help you. Might be worth reconsidering. Now, I'll bow out of this. Larry Report
October 4, 201115 yr comment_40108 Wise, very wise.Larry Jenkins said: Now, I'll bow out of this. Larry John MorrisThe Patriot Woodworker Report
