November 20, 201115 yr comment_37657 After I got the brushes at the point of ready for finish, i decided I'd work on trying to make an ornament, but i really wasn't sure what I wanted to make. After rounding the stock which is a small piece of Amboyna Burl, I started to make a cut on one end in a bead like fashion. I'm lucky I chose the end that I did to make that first cut because low and behold, there was a recess cut on the opposite end to true up the blank to the inserted tube. I instantly thought "you lucky dog, I'm going to make a bell out of this." So that is what i set to do. Â Here it is in the pre sanding stage, I'll have to work on it more later because I need to lay down for a while. I wanted the bell just a bit wider but the limit on stock size prevented that. i'll post the finished item later. Â Â Charles Report
November 20, 201115 yr comment_37662 You lucky dog indeed? Great looking piece of wood Charles and nice turning too! It's just flat out nice to see you producing again sir. Â John MorrisThe Patriot Woodworker Report
November 20, 201115 yr comment_37661 Nice! Great looking piece of wood. I'll bet the grain will really pop when you hit it with the finish.Lew Report
November 21, 201115 yr comment_37660 Charles, It looks wonderful. Welcome back to the world of turning!  Can't wait to see the finished product. SQ It it can't be fixed with glue and sawdust - it's not worth fixing. Report
November 21, 201115 yr comment_37659 Nice job Charles. I am looking forward to seeing it finished. I am sure it will look stunning. That is an awesome looking piece of wood. Glad you are turning again. John MoodyJohn Moody Woodworkshttp://www.johnmoodywoodworks.com Report
November 23, 201114 yr comment_37658 Maybe you could use a pen mill/barrel trimmer to remove the extended brass.Charles Nicholls said: Well as luck would have it, my hands are indeed steady enough to cut the first tiny part (about 1/4 inch) it's not quite shaped as well as i hoped but it works   AND THEN  Mr Murphy and his law decided to rear their ugly little heads  Yep you guessed it, that tube sitting there was pushed out when I tapped the first part in!  So rather than mess it up any further, I'll just wait to get the parts I need from PSI around the 1st.  To be continued  P.S, The wood sitting there to the right is the same wood I made the part from which is curly maple. Charles Report
