December 20, 201114 yr comment_36431 Dan! Great to see ya back around here! If your talking about a graphite lube for moving parts I have never used any, I have always gobbed a ton of paste wax on my trunion gears and any moving parts under the saw.Your question does raise a neat idea though, there should be some type of dry lube out there, that paste wax attracts sawdust and gets pretty messy after awhile. Anyone else?John MorrisThe Patriot Woodworker Report
December 20, 201114 yr comment_36430 Hey Dan, a Merry Christmas to you! What works for me is parrafin wax. Here in the midwest you can buy a 1# block of sealing parrfin that is used in canning food. i also use it on my planer. It doesn't attact dust and is clean.Ron DudelstonAbove and Beyond WoodWorks Report
December 20, 201114 yr comment_36429 So do you just break off pieces of the block and rub those in or do you warm it and get it to a liquid and them put it on the moving parts?I haven't thought about it for that. I use it to seal the end of turning blanks but I heat it and pour it on.Ron Dudelston said:Hey Dan, a Merry Christmas to you! What works for me is parrafin wax. Here in the midwest you can buy a 1# block of sealing parrfin that is used in canning food. i also use it on my planer. It doesn't attact dust and is clean.Ron DudelstonAbove and Beyond WoodWorks Report
December 20, 201114 yr comment_36428 I just rub it on. It is pliable enough to work into the teeth of a trunion and soft enought to rub onto the smooth surface of a ground rail.Ron DudelstonAbove and Beyond WoodWorks Report
December 20, 201114 yr comment_36427 Good deal, that is good information to have.thanksRon Dudelston said:I just rub it on. It is pliable enough to work into the teeth of a trunion and soft enought to rub onto the smooth surface of a ground rail.Ron DudelstonAbove and Beyond WoodWorks Report
December 21, 201114 yr comment_36426 Good info indeed! I never thought of Parrafin for this purpose. And it doesn't attract dust! Awesome!John MorrisThe Patriot Woodworker Report
