January 2, 201214 yr comment_35832 Ken , and Larry, I remember awhile back one you dropped me an email for a company that specializes in bearing replacements. Can you please leave that number here again? I cannot for the life of me track it down. Your help is greatly appreciated.John MorrisThe Patriot Woodworker Report
January 2, 201214 yr comment_35837 Accurate Bearings. Call 800-323-6548 ask for LynneMy job is to give my kids things to discuss with their therapist Report
January 3, 201214 yr Author comment_35836 Thanks KenKen Rasmussen said:Accurate Bearings. Call 800-323-6548 ask for LynneMy job is to give my kids things to discuss with their therapistJohn MorrisThe Patriot Woodworker Report
March 7, 201214 yr comment_35835 Walker Turner had an insidious habit of using odd sized bearings in some machines. Â This company can help you out with some of the special WT requirements. Â I suggest trying Accurate Bearing first to see if they can provide the size you need. Â Walker Turner Serviced Machinery, LLCPO Box 666Coventry, CT Â 06238wtsmllc@juno.com Report
March 7, 201214 yr comment_35834 Ray, Delta was also guilty of using what are now days odd size bearings in some machines. I suppose most of the machine makers were. What was a common size back then, is no longer so.   Larry OWWM Forum Host Ray Van Haecke (ravan) said: Walker Turner had an insidious habit of using odd sized bearings in some machines.  This company can help you out with some of the special WT requirements.  I suggest trying Accurate Bearing first to see if they can provide the size you need.  Walker Turner Serviced Machinery, LLC PO Box 666 Coventry, CT  06238 wtsmllc@juno.com Report
March 8, 201214 yr comment_35833 Using odd sized parts used to be common with a lot of manufacturers, it's a good way to keep you buying parts from them. Catapiller used to be notorius for this right down to things like o-rings even. GregScroll Saw forum hosthttp://www.thesawdustfactory.net/ Report
