January 27, 201214 yr comment_34690 So lets get this straight. If the formula for calculating the moisture content in wood is:Moisture Content (%) = Weight of Water in Wood     X100                                    ------------------------------------                                      Weight of Totally Dry WoodorWeight of water in wood divided by weight of dry wood X 100.So then we need to have a known base line of what that wood is supposed to weigh when dry right?John Morris The Patriot Woodworker Proud Supporter of Wounded Warrior Project and Homes For Our Troops Report
January 27, 201214 yr comment_34694 It appears that you would need a board that is know to be at a "dry" moisture content. If you know it has been dried to say 8% then you could use that as a baseline.John MoodyJohn Moody Woodworkshttp://www.johnmoodywoodworks.com Report
January 28, 201214 yr Author comment_34693 That appears to be right John!!!So I guess what we would need to do then is purchase a kiln dried board for our baseline and use it to determine when our wet lumber is ready.John MorrisThe Patriot WoodworkerProud Supporter of Wounded Warrior Project and Homes For Our Troops Report
February 19, 201214 yr comment_34692 ohn Morris said:So I guess what we would need to do then is purchase a kiln dried board for our baseline and use it to determine when our wet lumber is ready. Report
February 20, 201214 yr Author comment_34691 Cliff, great stuff and thank you so much! I was traveling down the wrong road with this then!Someday I want a small mill and a solar kiln, someday!John MorrisThe Patriot WoodworkerProud Supporter of Wounded Warrior Project and Homes For Our Troops Report
