January 28, 201214 yr comment_34661 You know I was in the tools forum reading up on Steve Newmans resto of his hand tools and he was mentioning how he uses a brass brush to knock of the stuff on his tools.I was curious what our machinery guys use at the wire wheel, brass or steel?John MorrisThe Patriot WoodworkerProud Supporter of Wounded Warrior Project and Homes For Our Troops Report
January 28, 201214 yr comment_34669 John,I use steel on cast iron parts, brass on sheet metal.Only because I find the steel holds up better doing cast, and are cheaper to buy. They are sometimes a little rough on sheet metal, so I use brass wheels on sheet. Larry Report
January 28, 201214 yr comment_34668 SteelMy job is to give my kids things to discuss with their therapist Report
January 28, 201214 yr comment_34667  IF it is on the grinder, then a steel wheel is used.    The brass BRUSH is to both get into the little spots a wheel can't get into, and, it tends to LEAVE any small details (like the "76" on a Liberty Bell) intact.   I also used the brass to scrub the gunk raised by any soaking I do to parts.    A nice soak in Simple Green, with a scrub with the hand-held brush works just fine.   I like to leave the details in place.  'and may the road raise up to meet ye' Report
February 7, 201214 yr Author comment_34666 Thanks for the info guys!!!!! I'll get back on my DP soon enough!!John MorrisThe Patriot WoodworkerProud Supporter of Wounded Warrior Project and Homes For Our Troops Report
February 25, 201214 yr comment_34665 Depends. If I care about not scratching:Â Brass. If all I want is rust removal: SteelIf I want to not transport plain steel to SSTÂ ( and cause rust)Â then it's SST. Report
February 25, 201214 yr Author comment_34664 Thanks Cliff, can you go into a little more detail on the last line of your reply. I am lost. I am kind of new to metal working so forgive my ignorance.Cliff said:Depends. If I care about not scratching:Â Brass. If all I want is rust removal: SteelIf I want to not transport plain steel to SSTÂ ( and cause rust)Â then it's SST.John MorrisThe Patriot WoodworkerProud Supporter of Wounded Warrior Project and Homes For Our Troops Report
February 26, 201214 yr comment_34663 Yah sure.SST is corrosion free only because the base metal (steel) has been alloyed with no less than 12% chrome. More is better and adding nickel also is better still, but 12% chrome is the minimum for SST. The different grades of SST 304 316 400 etc are different in the amount of chrome and nickel. Super alloys like Inconel and Monel are super saturated with nickel and chrome inter aliaAt 12%, when the metal exposed to atmosphere it will experience a deposition of a chrome oxide layer on the surface. That layer is what is called the passive layer. Passivisation is just an etching process that removes a little iron (but not the chrome) leaving a denser layer of chrome on the surface to form a denser chrome oxide layer.When plain steel or iron is abraded against the chrome oxide layer it can scrape it away and - can - leave some plain steel behind.  That steel that is left behind - can - bond to the SST and once it starts rusting can communicate the corrosion through itself into the SST where the passive layer can not form because it is never exposed to air ( O2).I say - can - because it also might not. But the fact that it can is cause for concern. For machine operations the wise engineer will specify that after machining the SST items made will also undergo an abrasive finishing process preferably followed by a passivisation process to ensure that any steel that may be stuck to the SST is removed.All that said: A steel wire brush is a good candidate for damaging a SST surface.If you have damaged SST surfaces you can passivate thm yourself with Citric Acid in water. Adding a little EDTA to chelate the iron is also a good idea. Industrial pssivation uses a specific molarity of nitric acid at a specific temperature over a specific time but Citric is way easier and strength of solution temp and time are things you can work with if you please but you can ignore them too.Conversely, muriatiac acid  ( & others too) will etch off the chrome and cause rust. Report
February 27, 201214 yr Author comment_34662 Great stuff Cliff, thank you so much, this is one to stick in my arsenal of knowledge as I jump into the realm of restoring old woodworking machinery. It's amazing the knowledge on our site, thanks again Cliff, that was great.John MorrisThe Patriot WoodworkerProud Supporter of Wounded Warrior Project and Homes For Our Troops Report
