February 27, 201214 yr comment_33276 I got G0555P 14" 1 HP Bandsaw, Polar Bear Series which I ordered in January and I did not realized it was a 2 speed until I started assembling it. It appears to be set on the low speed. To change it to higher speed I'll have to loosen the motor and slide it enough to move the belt. Question I have is which speed would I need to leave it on for most cutting.   I'm not really liking the idea of changing it every time I want to use it. Right now my main use would be for re-saw. Any opinion is greatly appreciated. Wayne E Wayne E Report
February 27, 201214 yr comment_33281 Of course the thickness (width? height?) of the cut will determine the optimum speed. Start it at the slow speed and see what it does on a piece that is the height you anticipate cutting. Is it variable, or just two speeds?Gene'The true soldier fights not because he hates what is in front of him, but because he loves what is behind him.' G. K. Chesterton Report
February 27, 201214 yr Author comment_33280 Gene Howe said:Of course the thickness (width? height?) of the cut will determine the optimum speed. Start it at the slow speed and see what it does on a piece that is the height you anticipate cutting. Is it variable, or just two speeds?It is 2 speed. Have to move the belt from one pulley to another. Just trying to find a happy medium in weekend usedThanksWayne EGene'The true soldier fights not because he hates what is in front of him, but because he loves what is behind him.' G. K. Chesterton Report
February 29, 201214 yr Author comment_33278 Thank youWayne ECliff said:For wood: highFor metal: Slow Report
February 29, 201214 yr comment_33277 Excellent!Cliff said:For wood: highFor metal: SlowJohn MorrisThe Patriot WoodworkerProud Supporter of Wounded Warrior Project and Homes For Our Troops Report
