April 16, 201214 yr comment_30923 Â I have a nice piece of unfinished wood that has a coat of stain/sealer on it. I want to glue some small pieces on top of the stain. What kind of glue will work in this situation? The pieces are decorations only, no strength required.Thanks Report
April 16, 201214 yr comment_30929 I think I would probably go with CA glue.Lew Kauffman-Wood Turners Forum HostTime traveler. Purveyor of the world's finest custom rolling pins! Report
April 16, 201214 yr comment_30928 Maybe scuff it up a little and then the CA glue.Harry BrinkBulldog WoodworkingMontana Report
April 16, 201214 yr Author comment_30927 I'll make a test run of CA and maybe some Goop. I've had Goop work where nothing else will. I am pretty sure that regular wood glue and epoxy won't stick. I didn't think about CA.Thanks Report
April 16, 201214 yr comment_30926 Over time, I've had the Goop let go. Some of these were outside projects and some just let go for no reason.Ron Altier said:I'll make a test run of CA and maybe some Goop. I've had Goop work where nothing else will. I am pretty sure that regular wood glue and epoxy won't stick. I didn't think about CA.Thanks Report
June 12, 201214 yr comment_30924 Only if they are long enough to clinch over on the back sideCliff said: 16 penny nails Report
