April 26, 201214 yr comment_30459 I'm building a Miter Saw station and I have some aluminum T Track I bought for the fence system from Rockler and I need to cut it. I've used a carbide blade in my table saw to cut thin aluminum but I'm not sure if can cut the T Track the same way. I don't want to use a hack saw if I don't have to as I would like a smooth cut.Have any of you cut it with a carbide saw blade before? Report
April 26, 201214 yr comment_30467 Yep, you can cut aluminum with a carbide saw blade. In fact the easiest and best way to cut aluminum is on your miter saw! It is non ferrous and very cut able.I wouldn't worry about the thickness of the t-track, I have cut aluminum door bottoms, weather stripping, 1/4" aluminum bar stock etc on a miter saw, with no adverse affects on the carbide or the blade.John MorrisThe Patriot WoodworkerProud Supporter of Wounded Warrior Project and Homes For Our Troops Report
April 26, 201214 yr comment_30466 Ditto what John said.Lew Kauffman-Wood Turners Forum HostTime traveler. Purveyor of the world's finest custom rolling pins! Report
April 26, 201214 yr comment_30465 I have cut aluminum with my table saw, miter saw, jig saw and circular saw as they all work well. You will need to do a bit of edge clean up on the cut  after the cut using a wire brush or wheel. But I WILL NOT use my good blades to do it with!!  I will use an older and/or more inexpensive blade set apart for cutting  stuff like this.Allen WorshamCorona, CAallenworsham@earthlink.nethttp://www.awcreationsandwoodcrafts.com'Graze in every man's field, but always give your own milk' J. Vernon McGee Report
April 26, 201214 yr comment_30464  One could always pick up a metal cutting blade for the Bandsaw.    'and may the road raise up to meet ye''and may the road raise up to meet ye' Report
April 26, 201214 yr Author comment_30463 Thanks guys for you reply's. I have a carbide blade that I use to cut pine and Douglas fir. It's the one that came with the saw.. Report
April 27, 201214 yr comment_30462 Â I've used the Dremel with a cut off wheel many a time for stuff like this tooGregScroll Saw forum hosthttp://www.thesawdustfactoryga.com/ Report
April 27, 201214 yr Author comment_30461 Greg I have too but I always seem to break the wheels. I have a dye grinder but I ran out of cut off wheels. I ended up using my miter saw and it cut it like butter. I really don't like cutting metal on the band saw or my Table saw unless I have to but the miter saw is easy to clean. Thanks all for your help and ideas! Report
May 29, 201214 yr comment_30460 I cut half inch aluminum jig plate with my table saw.  If you are going to do a lot of it get a non ferrous metal blade otherwise just use the blade you got. Report
