May 19, 201214 yr comment_29506 I moved the 30 " Wadkin band saw to the mill shop today. I have had this saw in the bench shop for a year now. Today I put the table on and ran some wood through it. Its an old blade 6 point so it not cutting great I will order a new 16.5 foot 3 point. This is a DMD(direct motor drive) saw with a blade SFPM(surface feet per minite) of 6476. The high speed saws are a little louder too.The wadkin has solid steel pulleys and so it takes some time to come of to speed.look at the dime at the very begining and it does shack just a bit.Enjoy I didyou sometimes wounder if theses machine will ever be done. here is a link to the rebuild for the answers to the machine specs.http://www.owwm.org/viewtopic.php?f=1&t=86300&hilit jackEnglish machine Report
May 19, 201214 yr comment_29511 Jack, Another fine member from the House of Wadkin. Looks like it's cutting fine to me. Â Larry Old Woodworking Machinery Forum Host Report
May 19, 201214 yr comment_29510 Once again beautiful work Jack. I noticed the series of holes in the table and am assuming for circle cutting?My job is to give my kids things to discuss with their therapist Report
June 3, 201214 yr comment_29509 Very impressive, I would be ecstatic with that cutting speed. must check my sfmp, when I'm in the mood for the brain teaserEnjoyed the post cheers S>Csam c Report
November 29, 201213 yr comment_29507 Impressive! Nice working with your band saw huh! Really fast. Take the first step, it will lead you to the LAST.www.bandsawblog.com Report
