October 8, 201214 yr comment_22822 I am going to build a porch swing style swing for my daughter. It will be hanging from an A frame and will be exposed to all types of weather. The sun out here is brutal on wood at this altitude (5800 ft)  I am not too familiar with the wood types available out here, but do know that big box carries a lot of red wood, cedar and some spruce. Questions 1. What wood would you use?2. Will the wood be as strong as the harder woods I have worked with? Oak, ie.3. Should I cut the wood thicker to compensate for any loss of strength?3. would you leave it as it is, with a sealer, or paint it?  Thanks Report
October 8, 201214 yr comment_22828 Ron I have and am building some for a client and they are out of white oak. The seat supports and back supports are 1 1/2" think and the slats are 1 1/2" wide and 1/2" thick. I am on my iPad now so I can't post a picture but I have posted some of those. I see some woodworkers around here that make them out of cedar. I have also seen some made from cherry and of course I see the out if treated lumber. My client was painting the white oak ones. I have seen some where they put varnish but you will have to do that probable each year. I think it would be the same if you used poly and it is outside. John MoodySite AdministratorJohn Moody Woodworkshttp://www.johnmoodywoodworks.com Report
October 8, 201214 yr comment_22827 I agree with John on the white oak. Red oak is way too porous for the weather. The ones I make have 1/2 slats also with no problems. I spray a spar urethane on mine. About 3 thin coats.Ron DudelstonSite AdministratorAbove and Beyond WoodWorks Report
October 8, 201214 yr Author comment_22826 The one I built of Cherry and coated with spar varnish, it looked really bad after just one year exposure out here.That is why I was considering the woods like cedar ,spruce,& redwood. The fences out here are built of unfinished cedar and last quite a while, mine is 15 years old. It is weathered and dry looking, but still pretty solid. So Red Oak is the better choice? Report
October 8, 201214 yr Author comment_22825 John, you mentioned treated wood, I had not thought about that. Not a bad idea. What are the cons on using it? Report
October 9, 201214 yr comment_22824 I would think cypress would be the best for outdoor projects.  www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops Report
October 9, 201214 yr comment_22823 white oak resists rot and is strong.I have a set of 9 Adirondack chairs that are permanent residents by my pool in NJ and they are PT spruce and painted.They've been good for about 5 years now. Report
