January 8, 201313 yr comment_18723 I know I don't participate often, but I thought this might be a good place to come for this. I am looking for a drum sander, or a way to construct one. I need something that is only 3-4 ft wide and has a place for multiple drums 2-3 inches wide. If anyone has any information I would greatly appreciate the help!Alyssa Report
January 15, 201313 yr comment_18737 Back to the top, this one was in the wrong category, sorry for the no reply Aly!John MorrisThe Patriot WoodworkerProud Supporter of Homes For Our Troops and Wounded Warriors Project Report
January 15, 201313 yr comment_18736 This is a 36" wide one. 48" may be stretching it for a shop made one.DRUM SANDERGene'The true soldier fights not because he hates what is in front of him, but because he loves what is behind him.' G. K. Chesterton Report
January 15, 201313 yr comment_18735 What is the purpose for the multiple drums? I could see it if you were to mount different grit paper to each drum and sand a piece of stock through three grits making it a one pass process. It would save a lot of time. Keep in mind the smaller the drum diameter the more heat will build up and not dissipate as fast.www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops Report
January 15, 201313 yr comment_18734 Typical of me, I thought Aly was thinking of multiple grits on one drum.Gene'The true soldier fights not because he hates what is in front of him, but because he loves what is behind him.' G. K. Chesterton Report
January 15, 201313 yr comment_18733 Using several drums, each with a separate grit would surely speed up the process but add to the size, complexity and horsepower required.I looked at a lot of designs for shop built sanders- some quite elaborate. If you have the resources ($ and facilities) I think building one would be doable.Lew Kauffman-Wood Turners Forum HostTime traveler. Purveyor of the world's finest custom rolling pins! Report
January 15, 201313 yr Author comment_18732 Sorry about the wrong category, I didn't know how to fix it when it happened.I actually make shoes and need the multiple drums for different purposes while making a shoe. I work with a very large drum sander every day but it is around 10' wide and is much too large for anything I will want when I have my own shop. I will use multiple grits within just a few minutes and do not want to slow down the process by having to change the sand paper every time I need a new gritIs there anywhere I can look to find these or directions on how to make one? Report
January 15, 201313 yr comment_18731 Aly, don't sweat it, it was not big deal being in the wrong category. I was more concerned your post was not getting the attention it should.Are you saying your a shoe maker, for human shoes? And if so, then the drums you need can be exposed, you just need the drums with different grits exposed to finish the shoes? We are not talking about a machine where wood actually gets fed between two tables right?Aly L said:Sorry about the wrong category, I didn't know how to fix it when it happened.I actually make shoes and need the multiple drums for different purposes while making a shoe. I work with a very large drum sander every day but it is around 10' wide and is much too large for anything I will want when I have my own shop. I will use multiple grits within just a few minutes and do not want to slow down the process by having to change the sand paper every time I need a new gritIs there anywhere I can look to find these or directions on how to make one?John MorrisThe Patriot WoodworkerProud Supporter of Homes For Our Troops and Wounded Warriors Project Report
January 16, 201313 yr Author comment_18730 Yes, I make human shoes . Â Nothing gets fed between two tables. Basically I want a machine like the one in this image, but instead of the brushes I want drum sanders with each one being about 2" wide and a proper way to not have dust everywhere. I think they can be exposed if I understand that term correctly. I have even considered using a dremel tool with the sanders they have for it, mainly it is too dusty. Report
January 16, 201313 yr comment_18729 Now that's a horse of a different color (To quote the Great and Powerful Oz). This could be easily made with a motor, a bench mandrel, rubber wheels and some hardware. Lew Kauffman-Wood Turners Forum HostTime traveler. Purveyor of the world's finest custom rolling pins! Report
January 16, 201313 yr comment_18728 Forgot, as for dust collection, Do you have an old range hood? You could set it close to the machine and vent it to the outside or even build a partial enclosure and connect a Shop Vac.Lew Kauffman-Wood Turners Forum HostTime traveler. Purveyor of the world's finest custom rolling pins! Report
January 16, 201313 yr comment_18727 What your looking for is like this or a solid rubber replacement tube from a feeding sander for boards. You could mount these on a shaft and put 2 different grits on each barrel. Dust collection is then just a matter of making a sheet metal hood or "scoop" under the wheel to suck up falling dust and dust off the drum. Report
January 23, 201313 yr comment_18726 Have you consulted the great, the wise, the all knowing, omnipotent, omniscient,  the Ayatollah of all-a-knowah - - google? http://www.riogrande.com/Product/Rubber-Expanding-Drum-with-Pop-Out-Bushing-6x-2-1-2/201088You buy belts to go over the wheels and they fit snugly Report
January 23, 201313 yr Author comment_18725 Thank you everyone for your input. I have some ideas now for what I need to do. Cliff, Google doesn't really like what I do and I don't think it believes shoe making exists, I have tried searching and nothing useful comes up. Report
January 25, 201313 yr comment_18724 People actually MAKE shoes? REALLY~!!???I thought they just sort of grew on store shelves.  Ya know the store people sprinkle little gimlets on the empty shelves and in the morning ~ ~ ~ ~ Report
