JIMMIEM
Which Wood for Project Prototype
Rate this topic
I'm about to start a new project which will be made out of Red Oak.  For past projects I have used easier to work woods e.g. Poplar or even MDF for the prototypes.  This project will require 6/4 wood.  I'd like to use Poplar but would have to do a glue-up of readily available 3/4 stock or drive to a hardwood supplier for the 6/4 stuff.  I could also cut down some Pine from 2 X boards.  I'll be doing a lot of routing and am wondering if the Poplar will be 'easier' on the bits than the Pine?  Negligible wear-n-tear difference?  Overthinking?
Thank You for any advice.
Share this post
Link to post
Share on other sites
I would go with the poplar, as the pine would probably result in a lot of pitch build up on your router bits, as well as on the teeth of your table saw blade.  As far as wear and tear on the bits, I wouldn't think there would be much difference.
Share this post
Link to post
Lew, I think I beat you to it for once.;)  I didn't think about painting though, but if I had, since the end product is to be out of red oak, I would have assumed that painting wasn't going to happen.  @JIMMIEM, was I right about that?
Share this post
Link to post
agreed...
poplar would be more stable
Share this post
Link to post
If you have any kind of sanders like drum sanders which takes lots of time to replace the sand paper I would say away from any kind of pine....Router bits are much quicker to clean up and cheaper than buying more rolls of sandpaper and the labor it takes ....
Share this post
Link to post
slow down, think it thru, do it once in oak.  if you need to make test cuts, that's what the scrap pile is for.  (getting the dado blade set for dado cuts/rabbit cuts, making sure the tenon will fit the mortise, etc).
Share this post
Link to post
No painting.  The final product will be Red Oak.  The Poplar (everybody's recommendation) will just be used for making a test/prototype.
Share this post
Link to post
if you are just making a prototype to get the lines and proportions right, and sort out your joinery, i'd go with the cheapest material option, which is NOT poplar.
either some scrap plywood, or some MDF.
if you need thicker than 3/4", just double it up.  glue sets in a hour.
your prototype won't see any use, won't take any load beyond it's own weight, so there is no point is spending more time or money than required.
personally, i'd use simple joinery on the prototype, like pocket screws or nails.
poplar isn't that cheap anymore.  cleaning tools is just part of keeping your shop running well.  i try to clean my blades before i start a project, and if they are getting too fouled, clean them midway thru again.  doesn't take that long, and ensures good final results with sharp cuts and clean lines.
Share this post
Link to post
If you are looking for material that you don't have to glue I would go to my lumber yard ad get some hemlock framing lumber. Hemlock has no pitch and cuts about like Doug fir, comes in 2X4- 2X12. We don't have pine here ,but lots of Hemlock.
Just saying ,
Herb
Share this post
Link to post
Based on past projects, such as rail and stiles, I found it easy to cut Poplar in one pass as opposed to red Oak that I had to do in multiple passes to avoid splintering.  Same thinking when making templates.
Share this post
Link to post
This project is counter top edging with a no-drip edge.  This detail is usually done on solid surface (Corian) material.  I'm not sure if it's even going to work out.  That's why I want to try it out on wood that's easy to work.  I've use MDF a lot for templates......but the even with good dust collection I don't like the dust.  I'd probably need a good plywood (Baltic Birch) which isn't cheap and not readily available in my area.
Share this post
Link to post
12 hours ago, Cliff said:
what's the cheapest  full size lumber you can get??  I'd avoid the mdf & other laminates because the glue is hard on even carbide tools.
Have you contacted a sawmill? Scraps  Offcuts?
No sawmills nearby.  I don't mind spending $ on prototype wood.  Trying to save $ by buying less expensive wood which may present other problems isn't worth it to me.
Share this post
Link to post
I use pine a lot.  I haven't found that much pitch in it, either the "select", "common" or stud KD (kiln dried).  I used KD pine to mock up my den doors; final material was red oak.  It doesn't sound like you need to do much mock-up for counter edging.  Wouldn't just a few straights tell the story?  Then you'd only have to test the oak for tear out and similar species-related issues?
Share this post
Link to post
3 hours ago, Dadio said:
Are there any lumber yards near?
Herb
Yes, there are a couple that I have used and fairly easy to get to.  The hardwood supplier is a little farther away.  I will go there for the Red Oak to buy by the Board Foot.
Share this post
Link to post
The corner piece will have a 2 inch radius to it.  There are a couple of no-drip edge bit styles.  The bearing guided bit would be easy to use on the straight pieces but not on the curved pieces.  I had thought about starting with all straight pieces and then steam bending some for the radiused corners.  A steam bending article said don't steam bend a piece that is thicker than its width....which is my scenario.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Who We Are
Operation Ward 57 Challenge Coin Display Project
We are a woodworking community with an emphasis on sharing and learning the skilled craft of woodworking and all of its related disciplines. Our community is open to everyone who wishes to join us. We support our American veterans and active duty, being a veteran is not a prerequisite to join. Join us now!
Objective
Air Force Command Center Plaque
Of course just like most online woodworking communities we are centralized in the arts, crafts, and trades that are woodworking. But, we have another focus in our Patriot Woodworker community, we are the only woodworking community that was founded on our care and concern for our disabled veterans.
Volunteer
Patriot Woodworker Volunteers
The Patriot Woodworkers are an all volunteer community, from the staff and hosts who run our online woodworking community to the members who frequent our forums, you'll find volunteers in all of us. We are not on a payroll, unless you consider the spiritual rewards gained from volunteering, as compensation.
Education
Logging
One of the many projects we are working on is a wiki for our online community. A wiki is a great way for woodworkers and enthusiasts to share their knowledge to others, and to impart their knowledge for others to learn from, and utilize as well for their own benefit. We hope you'll consider being a wiki contributor.
