Cliff
1 Ph Motor Plate Labeling
Rate this topic
I don't know what these terms mean
tape
ungr'd line
Do you?  My goal is to take advantage of the reversible feature with a rotary switch
here's pix
Does it mean they want you to connect these with tape or a wire nut?
Share this post
Link to post
Share on other sites
1 hour ago, Cliff said:
tape
connect together
ungr'd line
neutral..
(un-grounded)
Share this post
Link to post
32 minutes ago, Stick486 said:
connect together
2 hours ago, Cliff said:
ungr'd line
neutral..
(un-grounded)
thanks.   I was sort of sure that "tape" meant to tape it but the motor is not so old that tape would have the preferred connection.  They had wire nuts in the mid 1970s when I bought it.  But "Ungr'd" was a total mystery to me.
Share this post
Link to post
Cliff are you talking about hooking a switch up like this to the reversible motor??IMG_0460.JPG.db63b70801a9cbd0fa0ac7ea31a178cf.JPG
  if this is what you intend to use, I'll show some more pictures where it took 8 wires going from the switch to the motor...as I was changing an old saw in to an over head router set up.IMG_0461.JPG.78c22ee5a7d9f9577172294585d58c4c.JPG
Share this post
Link to post
so wire nut it...
Share this post
Link to post
drum switches are your best bet...
P1 is your neutral...
P2 is your line voltage...
2013-12-29_135054_old_emerson_and_dayton_drum_switch.jpg.0c938149a80821aad41fde77ed4d95df.jpg
              s-l1000.jpg.56da24aef36be318edbbb5f1a741bcef.jpg 8000790.jpg.56229ab6aa11378ca26ad77fca9d8d70.jpg
Edited by Stick486
Share this post
Link to post
P1 the ungrn'd is the line side of the overcurrent protection and the hot side of the 120v supply is connected to this, the neutral side of the 120v supply is connected to what is marked line where T2,T5,and T4 are conned together.   This is done so if the protector trips the windings would not remain energized.    When connected for 240v the windings will remain energized from the other side of the line when the protector trips.   It will work either way but they properly advise which is best for 120v.    Roly
Edited by Roly
Share this post
Link to post
 I assume the numbers on your drawing are the switch terminal numbers.   What motor wires did you connect to which switch terminal numbers ?     I also assume the numbers on the left side is for one position of the switch and the other side is for the other switch position and the opposite sides are all open when one side is closed and all are open when switch is in the off position,  Correct ?  And a final question is the motor
connected for 120v or 240v ?    Roly
 What type of switch is it ?  Does not look like a normal motor reversing switch like Stick drew.
Edited by Roly
Share this post
Link to post
OK  I broke down and got a Dayton Drum switch.  I wanted to use the cheap taiwanese ( $28) cam switch but it just gave me fits when trying to wire it.
Share this post
Link to post
I see the need for two double pole double throw switches.  One switch switches the T5 and T8 back and forth between the pairs of wiresP2-T3 and T2-T4.  and the another to switch the line voltage to either T5 or T8 as needed and then make note which way the switches need to be for FWD or REV.
Edited by HandyDan
Share this post
Link to post
Just one double pole double throw switch.switch.JPG.ab69dbc6c399a043bf0b1937d44eee29.JPG  Roly     CORRECTION   the P2 on the drawing should be P1  as this is the motor overload which would be in     CORRECTION   the P2 on the drawing should be P1  as this is the motor overload which would be in the ungrounded line (hot)
Edited by Roly
Share this post
Link to post
 This is just the reversing switch another on-off switch is needed before L1.    Roly
Share this post
Link to post
well got r up and running.  There's a goofy scraping noise.  I can't quite call it a bearing  but it sounds like there's a  shim stock or bit of roof  flashing rubbing one of the pulleys. But of course there's no such thing.
I think I want to isolate and solve for that.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Who We Are
Operation Ward 57 Challenge Coin Display Project
We are a woodworking community with an emphasis on sharing and learning the skilled craft of woodworking and all of its related disciplines. Our community is open to everyone who wishes to join us. We support our American veterans and active duty, being a veteran is not a prerequisite to join. Join us now!
Objective
Air Force Command Center Plaque
Of course just like most online woodworking communities we are centralized in the arts, crafts, and trades that are woodworking. But, we have another focus in our Patriot Woodworker community, we are the only woodworking community that was founded on our care and concern for our disabled veterans.
Volunteer
Patriot Woodworker Volunteers
The Patriot Woodworkers are an all volunteer community, from the staff and hosts who run our online woodworking community to the members who frequent our forums, you'll find volunteers in all of us. We are not on a payroll, unless you consider the spiritual rewards gained from volunteering, as compensation.
Education
Logging
One of the many projects we are working on is a wiki for our online community. A wiki is a great way for woodworkers and enthusiasts to share their knowledge to others, and to impart their knowledge for others to learn from, and utilize as well for their own benefit. We hope you'll consider being a wiki contributor.
