Rate this topic
Safety switch is a CYA button. We may not need it but, Rigid's legal staff probably insisted. And, the staff at HD aren't qualified to administer IQ tests.:lol:
Share this post
Link to post
Share on other sites
So, I'm not the only one aggravated by those little switches/buttons! I have to agree with Herb and Gene, they are only needed for kids, people with IQ's somewhere around room temperature, and people who burn themselves with HOT coffee at McD's.
Share this post
Link to post
2 hours ago, Dadio said:
tried the sawzall
Last time i got a couple of steel barrels and wanted to cut the heads out I used my Ridgid sawzall (used to use my B&D jigsaw) and (believe it or not) a nice new HF metal blade.   Zipped those babies right out and when i was done the only change was the paint on the saw blade was worn away from the friction.   Blade seemed sharp as new.
Share this post
Link to post
Go Harbor Freight,
going to have to get some of those blades,
The trigger safety button on the reciprocating saw is a straight push button, the circular saw is a press down type
Herb
Edited by Dadio
Share this post
Link to post
Use a right angle grinder on top of the rim until you see a line between the two pieces of metal that make up the lip.  The top will pop out and leave a nice smooth edge.
Share this post
Link to post
I was always told to fill the barrel with water before I cut the top off, is that a Myth?
Share this post
Link to post
Like all of you advised, to register the tools with Ridgid,
I did register them yesterday and got a confirmation back last night. a whole wad of paperwork to file away and hopefully never have to look for again.
It is easy to register, just takes time and a lot of numbers to type (8 items X 2 no.+ P.O.#), all 7-14 digits long. and then they make you check them twice, Whew, my one finger was numb when I got through.
Herb
Share this post
Link to post
I would have thought about it, but there was still a small amount of oily residue in them and the saw made it smooth enough for a fire barrel without sparklies.  :lol:
Share this post
Link to post
Good thing because many of them could not pass one, no less administer one.    Insert OAG Dumb Look©   here
Share this post
Link to post
Aw come on.  Where is your sense of adventure?  You are making a "burn" barrel.
Share this post
Link to post
Mine was for flushing the OB motor. But maybe the sawblade does not cause enough sparks, I used a hammer and cold chisel. but I still filled it with water, like my Dad had taught me. He used an acetylene torch.
Herb
Share this post
Link to post
Dan I agree with the using the grinder, especially if a person will working in and out of the barrel like when wife kicks me out of the house and says go sleep in the barrel... or when I built a kids thingy to crawl from one little play room to another up in the tree..but then we lost one kid and the other one didn't want to play anymore.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Who We Are
Operation Ward 57 Challenge Coin Display Project
We are a woodworking community with an emphasis on sharing and learning the skilled craft of woodworking and all of its related disciplines. Our community is open to everyone who wishes to join us. We support our American veterans and active duty, being a veteran is not a prerequisite to join. Join us now!
Objective
Air Force Command Center Plaque
Of course just like most online woodworking communities we are centralized in the arts, crafts, and trades that are woodworking. But, we have another focus in our Patriot Woodworker community, we are the only woodworking community that was founded on our care and concern for our disabled veterans.
Volunteer
Patriot Woodworker Volunteers
The Patriot Woodworkers are an all volunteer community, from the staff and hosts who run our online woodworking community to the members who frequent our forums, you'll find volunteers in all of us. We are not on a payroll, unless you consider the spiritual rewards gained from volunteering, as compensation.
Education
Logging
One of the many projects we are working on is a wiki for our online community. A wiki is a great way for woodworkers and enthusiasts to share their knowledge to others, and to impart their knowledge for others to learn from, and utilize as well for their own benefit. We hope you'll consider being a wiki contributor.
