Rate this topic
Hello,
My grandfather gave me all of his wood turning tools that he brought with him from overseas before moving to the greatest country, America. I’m wanting to fix up the wood lathe. Do you guys have any 1hp+ motor(s) suggestions? I have even noticed folks using motors from other types of equipment to run lathe. I’m hoping to stick around $200 range.
thank you!
Share this post
Link to post
Share on other sites
knowing more about the equipment would be a help...
brand...
drive arrangement..
Share this post
Link to post
I remember Germany's electric motors run on 50 cycle. I brought a reel to reel tape recorder, player back with me when I was over there and playing some of the stuff I recorded over there, running it on 60 cycle here made everything sound weird.. Been a long time ago and I might have the cycles reversed.... I do that some...
  If its electric motors from overseas maybe they can up the cycles for here.
Share this post
Link to post
That is funny, I thought the 50 Hz. was 220V, were you plugged into the range or dryer circuit?
Herb
Share this post
Link to post
The first place I plugged it in was the fire station in to a regular receptacle in the rec room. Was not 220. then later after I bought a house I used all the plugs in the house which was 110. I was told  after checking someone Germany's current came shooting out at 50 cycles and maybe theirs was 120 instead of 110??? like I said its been 60 years since I came back from Germany....Yes I could google Germany and see what they had back then...Another thing ,, I never seen a round door knob all the time I was over there...Was such a good idea, we have no round door knobs in our house now..
  Herb check out Germany for me, I'm lazy.
Share this post
Link to post
Germany is 230v 50 Hz, I didn't realize there were so many different combinations and plugs.
https://www.rei.com/learn/expert-advice/world-electricity-guide.html
Herb
Share this post
Link to post
I bought a 1.5 hp. from Harbor Freight for $169 on my band saw, then had to buy a pulley as the new motor has a Metric shaft, and my old pulley would not fit.
I had put a riser block in the band saw and wanted to increase the HP. from 1 to 1.5 hp. and put it on 220v.
Herb
Edited by Dadio
Share this post
Link to post
I was hoping to stick with 120 volt motor replacement if possible. My wood Lathe can handle up to 14” x 44”
thanks for the input!
Share this post
Link to post
Grizzley and HF both have 120v. 1 hp. motors.
the 1725 rpm.  https://www.amazon.com/Grizzly-G2905-Single-Phase-Motor-HP/dp/B0000DD1EP
The 3450 rpm     https://www.amazon.com/Grizzly-G2533-Motor-Single-Phase-3450/dp/B00DQJOZ08
Herb
Edited by Dadio
Share this post
Link to post
When shopping for an electric motor its good to take the bolt pattern, shaft size, rotation direction, if it is not reversible, and very important, if it has ball bearings or sleeves.  I have noticed Dayton supplies lots of their motors with sleeves. Not good for continues s running. And sometimes its good to have an AC-DC motor for certain applications. Or use to be... In my garage saleing, number one on the list has always been keep an eye on used electric motors for sale...To me, it is always cheaper to buy an electric motor when you don't need it...And almost any bolt pattern can be adapted if a person has a welder, drill press and some common sense..
Share this post
Link to post
Don't forget the RPM's,and voltage, other wise all what you said.
Herb
Share this post
Link to post
Thanks Herb, I knew if I left some things out you could come along and give me a hand. I just thought some things guys would know already. Thanks
Share this post
Link to post
Awesome, I am currently shopping around for the perfect replacement motor.
P.s this website is amazing
Share this post
Link to post
Also the people selling a used motor will always let you plug it in so you can listen to it run, if they won't, don't even think of buying it no matter how cheap.  A loud ball bearing is not a big deal, for bearings can be bought at a bearing supply. And even if a person thinks it might be over his head to change the bearings, a motor repair place might change them out while you wait..They will also replace a capacitor while you wait. Three or four years ago it cost about 20 bucks. This is something an electric motor usually needs when it just sits there and won't start running.
Garage sales are a good place to start looking..And always carry a list of things you might be looking for while browsing...
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Who We Are
Operation Ward 57 Challenge Coin Display Project
We are a woodworking community with an emphasis on sharing and learning the skilled craft of woodworking and all of its related disciplines. Our community is open to everyone who wishes to join us. We support our American veterans and active duty, being a veteran is not a prerequisite to join. Join us now!
Objective
Air Force Command Center Plaque
Of course just like most online woodworking communities we are centralized in the arts, crafts, and trades that are woodworking. But, we have another focus in our Patriot Woodworker community, we are the only woodworking community that was founded on our care and concern for our disabled veterans.
Volunteer
Patriot Woodworker Volunteers
The Patriot Woodworkers are an all volunteer community, from the staff and hosts who run our online woodworking community to the members who frequent our forums, you'll find volunteers in all of us. We are not on a payroll, unless you consider the spiritual rewards gained from volunteering, as compensation.
Education
Logging
One of the many projects we are working on is a wiki for our online community. A wiki is a great way for woodworkers and enthusiasts to share their knowledge to others, and to impart their knowledge for others to learn from, and utilize as well for their own benefit. We hope you'll consider being a wiki contributor.
