Rate this topic
25 minutes ago, kmealy said:
Well, I have two of them.
get the LV over the LN...
http://www.leevalley.com/us/wood/page.aspx?p=46791&cat=1,41182,41189,46791
http://www.leevalley.com/us/wood/page.aspx?p=56665&cat=1,230,41182
no need for the Starretts as long as what you do have is accurate...
Share this post
Link to post
Share on other sites
Got two. The little Bosch router and the pull saws...got several of those. My Combo squares are all Stanley rust hunt finds.
Share this post
Link to post
I have the Starett 4" combo square and the Starett 12 " combo with the Center head and protractor head.
Share this post
Link to post
I sold my Starrett,and bought 2 Stanleys, I have several pull saws but like my LV/LN Gents saw best. To me the Starrett is overkill for wood working, great for when I was metal working. 4 trim routers,none Bosch, waiting for them to wear out before I buy a Bosch.
Share this post
Link to post
Are you saying perfect 90's are overkill for woodworking ?:blink:
Share this post
Link to post
any square that is accurate will do that...
Share this post
Link to post
No, but .001" are.
I spent almost 20 years as a machinist/toolmaker   It taught me that  the ability to measure  very closely is never a disadvantage and that   tolerance stack can best be addressed by working to the tightest tolerances   possible.
Share this post
Link to post
Amazing any furniture pieces made by the Shakers and other 18th century craftsman even survived w/o use of these tools or electricity...just sayin
Share this post
Link to post
It was achieved Dave, but in today's world, if you want to make a living at it, accurate tools and power tools are needed to keep you competative. Speed is definitely a factor today.
Share this post
Link to post
You're right Dave. That degree of accuracy is a bit of overkill. I definitely wouldn't try to compare my woodworking skills to that of some of the folks here. My problem with the cheaper combination squares is that  they are usually made of materials that don't hold the accuracy over time, either because of over tightening , or dropping, or bending etc. I've dropped my Starett several times over the years. What happens is the tightening pin usually breaks, but they are  easily replaceable. I usually keep at least one pin on hand. I 've never bent a rule or even  broken the level on the Starett. With confidence, it has always been my "go to" tool to check the accuracy of the 90's and 45's that are cut on TS, SCMS, and BS.
Share this post
Link to post
Have 12" Starrett but without protractor head, 4" LV double square, Ridgid trim router, two Dozukis one crosscut, one rip cut, and LV low angle block plane. My most reliable 90 degree device in my table saw sled that sighted in via the 5 cut method ala William Ng.
Share this post
Link to post
For accuracy I check with a plastic drafting triangle. Then there is the old line on the bench , flip the square mark again . Then compare the lines for parallel.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Who We Are
Operation Ward 57 Challenge Coin Display Project
We are a woodworking community with an emphasis on sharing and learning the skilled craft of woodworking and all of its related disciplines. Our community is open to everyone who wishes to join us. We support our American veterans and active duty, being a veteran is not a prerequisite to join. Join us now!
Objective
Air Force Command Center Plaque
Of course just like most online woodworking communities we are centralized in the arts, crafts, and trades that are woodworking. But, we have another focus in our Patriot Woodworker community, we are the only woodworking community that was founded on our care and concern for our disabled veterans.
Volunteer
Patriot Woodworker Volunteers
The Patriot Woodworkers are an all volunteer community, from the staff and hosts who run our online woodworking community to the members who frequent our forums, you'll find volunteers in all of us. We are not on a payroll, unless you consider the spiritual rewards gained from volunteering, as compensation.
Education
Logging
One of the many projects we are working on is a wiki for our online community. A wiki is a great way for woodworkers and enthusiasts to share their knowledge to others, and to impart their knowledge for others to learn from, and utilize as well for their own benefit. We hope you'll consider being a wiki contributor.
