Ron Altier
Grandfather clocks are a pain
Rate this topic
If you are thinking about building a grandfather clock
I built a grandfather clock from a kit from Emperor Clock in the 70s for my wife. I had few tools and little space, so a kit was the only way. I built one from scratch about 10 years ago for my daughter.
Both clocks require a yearly cleaning/lubrication. Moving one is also a task. You must remove weights, pendulum  and secure everything else. After you move the clock to do anything at all, you must level it so that the pendulum has balanced travel. All weights do not weigh the same and you must be sure you put the proper weight in where it belongs. When I see a clock in someone's home, it is usually not running, due to lack of attention. It costs to have them cleaned and cared for. Now that I am older and have problems with my hands, this maintenance is twice as difficult. Big hands in small places don't work well. Of course a dropped tiny piece always goes to the most difficult location. The older clock is worn and does not chime properly.             I'm thinking that it will stay that way:rolleyes:
Share this post
Link to post
Share on other sites
Not to mention that some of those mechanisms can get downright expensive.
Share this post
Link to post
I got married in 1960 and wife gave me a Emperor clock kit in 1962 for Christmas but didn't put it together for about five years after that but its still running. Ron maybe you got too much oil on yours. I have never oiled this one yet.. One time some years later she was cleaning around it and knocked it over and put a big dent in the front of it but it didn't stop running. My sound board screws got loose and had to tighten them back up to make it sound good again is the only problem I have had so far.
...My brother in law gave me a big Ridgeway brand he could not make run,, I filled the bottom with news papers and sprayed a can of WD 40 on all the gears and wheels and things that moved and it has never stopped now for about 15 years.
Share this post
Link to post
I built two using a battery operated mechanism.  Both been running for 15 or more years and the batteries last two to four years.  Someone already mentioned the finicky mechanical ones are expensive.
Share this post
Link to post
I've never heard of one running for 15 years with maintenance.  However there a couple of things that affect that.  A pricy movement has many more jewels in it and will run longer. The atmosphere around the clock (dust, etc) also plays a big part.  Lastly.........if you don't wind them they don't run..............a little problem my wife has.:D
Share this post
Link to post
So what's with all this clock discussion...I thought you guys were retired?:lol:
Edited by Grandpadave52
Share this post
Link to post
Grandfather clocks are to be looked at with admiration. Who needs them to keep time? You are probably wearing a wrist watch.
Share this post
Link to post
We bought a Ridgeway in 95 and the guy who set it up said it needed cleaning and lubricating but did not say every year. It has never been cleaned nor lubed and is still on the dot.  Klockit used to have a cleaning kit but I cannot find it now.
Share this post
Link to post
Amazon has clock oilers. To do it right, you need to remove the mechanism so the bering points, behind the face, are exposed. Takes longer to remove the clockworks than to do the oiling.
Share this post
Link to post
25 minutes ago, lew said:
Those clocks are terrible for naps- their chimes wake you up!
Oh yeah, forgot about that, Lew, your right can't get to sleep before it changs again.
Herb
Share this post
Link to post
Herb
Well, I guess I'm lucky- I take out my hearing aids :D
Share this post
Link to post
Jointer, I was wondering why some clocks seem to go on very long times without care, So I found a video that could explains it. My original directions said to oil (I think) every year. This video says every 2 years and explains why clocks can run for decades and never be oiled.  He also said repair and replacement can be very  expensive. However if you have the skills to do it, it can be far cheaper than frequent oiling/cleaning by a pro (he didn't say that, but I'll bet it would cost a bunch more.)
Share this post
Link to post
We found my Grand Fathers 6' hi clock under the hay in the back of the barn years later when we cleaned out everything and sold the place. I was just a small boy then but the clock was coming apart at the seams and the mice had a home in it. I think it went into the junk pile and was hauled off to the metal salvage place.
Herb
Share this post
Link to post
So Ron... what is the answer?  Or do we have to watch the video?:rolleyes:
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Who We Are
Operation Ward 57 Challenge Coin Display Project
We are a woodworking community with an emphasis on sharing and learning the skilled craft of woodworking and all of its related disciplines. Our community is open to everyone who wishes to join us. We support our American veterans and active duty, being a veteran is not a prerequisite to join. Join us now!
Objective
Air Force Command Center Plaque
Of course just like most online woodworking communities we are centralized in the arts, crafts, and trades that are woodworking. But, we have another focus in our Patriot Woodworker community, we are the only woodworking community that was founded on our care and concern for our disabled veterans.
Volunteer
Patriot Woodworker Volunteers
The Patriot Woodworkers are an all volunteer community, from the staff and hosts who run our online woodworking community to the members who frequent our forums, you'll find volunteers in all of us. We are not on a payroll, unless you consider the spiritual rewards gained from volunteering, as compensation.
Education
Logging
One of the many projects we are working on is a wiki for our online community. A wiki is a great way for woodworkers and enthusiasts to share their knowledge to others, and to impart their knowledge for others to learn from, and utilize as well for their own benefit. We hope you'll consider being a wiki contributor.
