Showing results for tags 'water base colors'.
More search options
    • Tools, Research, Reviews and Safety
    • The Classified, Swap and Sale
    • Patriot Woodworker Member Meetings
    • Network Tutorials
  • The Patriot Woodworkers Archived Forum
  • Old Hand Tools
  • New Hand Tools
  • Freedom Caps
  • T-Shirts
Marker Groups
Joined
Group
First Name
Last Name
My Location
My Woodworking Interests
My skill level is
Website URL
Favorite Quote
AIM
MSN
ICQ
Yahoo
Jabber
Skype
Facebook URL
Twitter Feed URL
My Clubs and Organizations
  1. I have to put a few coats of clear over the glitter so it won't get stuck in little fingers. And little fingers likes bright colors...as does dull old men! This map I used a #3 Flying Dutchman saw blade for I wanted less gaps between the pieces.... and so I am afraid there ain't enough gap left for small girls and boys as they attempt to put the pieces in to the puzzle... The next puzzle will be cut with a #5 blade. If the map was to be put together one time then hung on the wall for looks the #3 is the one to use. I made the two additions down at the bottom a little different for I cut out the states, stained and sprayed them then slid them out a hair then glued the pieces up so they will stay in that position. I am adding the names of the states and their capitals on the back sides of each state and with the real small states that will be a problem! Another first, before I started making these maps I never knew Michigan was two different bodies...I always thought upper Michigan was a swamp or something and no one wanted to claim it??? This map is about 30" wide so I had to be a little careful as to how I sawed it out...…...as I only have a 20" Dewalt. I used 1/4" Baltic birch for both pieces of plywood...
